Slutters Posted June 16, 2013 Share Posted June 16, 2013 I have been through a few mappers, 3 infact, 1 on the road, 1 on the dyno and the last on a Dynapack! The last, in my opinion was the best, despite the engine going bang. This is just to show you, you get what you pay for! Link to comment Share on other sites More sharing options...
T2 MSW Posted June 16, 2013 Share Posted June 16, 2013 Thats a mess, whats the story? Link to comment Share on other sites More sharing options...
Slutters Posted June 16, 2013 Author Share Posted June 16, 2013 Detonation, well that was the story! Link to comment Share on other sites More sharing options...
imi Posted June 16, 2013 Share Posted June 16, 2013 Regardless of how good the mapper is there is no way they can guarantee the condition of a used car working beyond Toyota's original specs - there is always inherent risk in mapping a car. Link to comment Share on other sites More sharing options...
T2 MSW Posted June 16, 2013 Share Posted June 16, 2013 Caused by what, something failing or bad mapping? Link to comment Share on other sites More sharing options...
Slutters Posted June 16, 2013 Author Share Posted June 16, 2013 Bad mapping. There was det in all the cylinders. - - - Updated - - - Regardless of how good the mapper is there is no way they can guarantee the condition of a used car working beyond Toyota's original specs - there is always inherent risk in mapping a car. True, although detonation is preventable... Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 16, 2013 Share Posted June 16, 2013 Surely any mapper worth his salt would be mapping using det cans electronic or mechanical, so how was the engine detting enough to do that? only things i can think of apart from bad practice, are injector/fuel pressure failure, bad fuel or over boost. Link to comment Share on other sites More sharing options...
T2 MSW Posted June 16, 2013 Share Posted June 16, 2013 Surely any mapper worth his salt would be mapping using det cans electronic or mechanical, so how was the engine detting enough to do that? only things i can think of apart from bad practice, are injector/fuel pressure failure, bad fuel or over boost. Screams no det cans or pushing the limits to the extreme Link to comment Share on other sites More sharing options...
Graham1984 Posted June 16, 2013 Share Posted June 16, 2013 I would be a mixture of gutted and peed off to say the least. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 16, 2013 Share Posted June 16, 2013 Bad mapping. There was det in all the cylinders. - - - Updated - - - True, although detonation is preventable... And this mapper was the best of the bunch! Best let people know so they can avoid. Link to comment Share on other sites More sharing options...
Slutters Posted June 16, 2013 Author Share Posted June 16, 2013 Surely any mapper worth his salt would be mapping using det cans electronic or mechanical, so how was the engine detting enough to do that? only things i can think of apart from bad practice, are injector/fuel pressure failure, bad fuel or over boost. Indeed. Injectors are new, and were flow tested before they were fitted, fuel pressure was adjusted and evidenced marked and boost was set by the ECU. One of the mappers had used a rediculos amount of timing all over the place, 29 degrees where it needed 17 degrees. Link to comment Share on other sites More sharing options...
Slutters Posted June 16, 2013 Author Share Posted June 16, 2013 And this mapper was the best of the bunch! Best let people know so they can avoid. I know what you are saying, however i won't name anyone as i cannot be sure who's map caused it. I just wanted people to chose there mapper carefully. Link to comment Share on other sites More sharing options...
Scott Posted June 16, 2013 Share Posted June 16, 2013 I know what you are saying, however i won't name anyone as i cannot be sure who's map caused it. I just wanted people to chose there mapper carefully. Surely the last map caused it? If it was one of the previous ones this would have been spotted as soon as the latest map began. 29 degrees of advance has to set off alarm bells? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 16, 2013 Share Posted June 16, 2013 I know what you are saying, however i won't name anyone as i cannot be sure who's map caused it. I just wanted people to chose there mapper carefully. Should be very easy to distinguish which it was by the period of time in between maps:eyebrows: Link to comment Share on other sites More sharing options...
Slutters Posted June 16, 2013 Author Share Posted June 16, 2013 Surely the last map caused it? If it was one of the previous ones this would have been spotted as soon as the latest map began. 29 degrees of advance has to set off alarm bells? My take on it was, the damage was already done, the final mapper spent a good hour or so fixing the old map and got to the point where he was doing the boost stuff, got to 1.3 bar and as he lifted of a puff of smoke and i lost a cylinder. I think the damage was already there and that final boost run pushed it over the edge. Link to comment Share on other sites More sharing options...
Slutters Posted June 16, 2013 Author Share Posted June 16, 2013 Should be very easy to distinguish which it was by the period of time in between maps:eyebrows: I have my suspicions.... Link to comment Share on other sites More sharing options...
Scott Posted June 16, 2013 Share Posted June 16, 2013 My take on it was, the damage was already done, the final mapper spent a good hour or so fixing the old map and got to the point where he was doing the boost stuff, got to 1.3 bar and as he lifted of a puff of smoke and i lost a cylinder. I think the damage was already there and that final boost run pushed it over the edge. Bingo, that was my point. So the guy who did the most recent work was fixing the errors from the previous map(s). So it's the previous couple that are in question then? For the sake of fairness I would, objectively, let the good folks on here know who the mappers were. No conjecture, just fact. You may find corresponding history from other customers. Link to comment Share on other sites More sharing options...
Slutters Posted June 16, 2013 Author Share Posted June 16, 2013 Ok, i cannot say who caused the damage, all i am stating here is who has mapped the car. I am making NO accusations! The mappers were: Martin of MB Automotive (Road mapped) Austec Racing (Dyno mapped) I will reiterate, i have no proof and wish to make NO accusations! - - - Updated - - - Spec of car stayed exactly the same. Link to comment Share on other sites More sharing options...
imi Posted June 16, 2013 Share Posted June 16, 2013 Agree with Scott Plenty of money grabbing cowboys around Link to comment Share on other sites More sharing options...
j_jza80 Posted June 16, 2013 Share Posted June 16, 2013 Could you at least tell us what ECU you're using? Link to comment Share on other sites More sharing options...
Slutters Posted June 16, 2013 Author Share Posted June 16, 2013 Could you at least tell us what ECU you're using? AEM at the time, both mapped the car on AEM V1. Link to comment Share on other sites More sharing options...
Scott Posted June 16, 2013 Share Posted June 16, 2013 Ok, i cannot say who caused the damage, all i am stating here is who has mapped the car. I am making NO accusations! The mappers were: Martin of MB Automotive (Road mapped) Austec Racing (Dyno mapped) I will reiterate, i have no proof and wish to make NO accusations! - - - Updated - - - Spec of car stayed exactly the same. I would say that's fair enough, who was the 3rd mapper though? Link to comment Share on other sites More sharing options...
Sheefa Posted June 17, 2013 Share Posted June 17, 2013 I would say that's fair enough, who was the 3rd mapper though? Yes, who was the last mapper or was it Austec twice? Link to comment Share on other sites More sharing options...
mellonman Posted June 17, 2013 Share Posted June 17, 2013 sorry to see this mate , what a mess i cant believe that someone could get the timing so much out 12 degrees is quite abit Link to comment Share on other sites More sharing options...
Fly Posted June 17, 2013 Share Posted June 17, 2013 ouch!! thats never a good sight Link to comment Share on other sites More sharing options...
