Mace Posted June 15, 2013 Share Posted June 15, 2013 For those who don't know I bought a stripped down UK supra and I'm currently trying to put it back together so it runs/ drives ok. Problem is I kind of don't know whats missing. In some cases it obvious and some things I don't want or need like active spoiler. Behind the radio there is an ecu bolted on the transmission tunnel with no label on it i''m hoping is ABS, There's a plug for something on top of it which is missing and a plug hanging down to the left higher up which i'm not sure about. Also where is the Ecu for cruise control? it doesn't function so if its missing the ecu i'll just get rid of it.. Quote Link to comment Share on other sites More sharing options...
keron Posted June 15, 2013 Share Posted June 15, 2013 Cruise ecu is behind in the dash... Sort of above your left knee when sittin in the car, about cig lighter level... Best to get to it via the panel with the bonnet release cable in... Take that panel off and look up ... It will have a green connector plug - - - Updated - - - If you need to know what missing, best to get some pics of the areas mentioned so we can see what's missing maybe?? Quote Link to comment Share on other sites More sharing options...
Mace Posted June 15, 2013 Author Share Posted June 15, 2013 Yep that's missing explains it not working. I'll take a pic but basically there is the one ecu bolted to the tunnel and the two plastic ones on the radio for the aircon and radio and that's all that's there. Turns out the airbag ecu is uk spec specific, I bought a SRS ecu from a jspec and its completely different.. Quote Link to comment Share on other sites More sharing options...
keron Posted June 15, 2013 Share Posted June 15, 2013 Yeh airbag ecu is different... I have a uk one on shelf Quote Link to comment Share on other sites More sharing options...
keron Posted June 15, 2013 Share Posted June 15, 2013 Behind the stereo usuall you get abs ecu, active spoiler ecu, then on top of the stereo a cream box for heaters with orange plugs, a aerial antenna relay (brown box) on top of the cream one... Grey plug iirc Quote Link to comment Share on other sites More sharing options...
Mace Posted June 15, 2013 Author Share Posted June 15, 2013 Cheers mate, How much will an airbag ecu set me back these days? it looks like just the active spoiler ECU missing then and I wont be needing that Quote Link to comment Share on other sites More sharing options...
