Guest micke547 Posted June 14, 2013 Share Posted June 14, 2013 Hi everyone! Bought a wonderful supra TT 6spd 1994 j-spec a few weeks ago, and it seems to have some issues when shifting description of the problem: when shifting it feels like something in the gearbox punches back lightly through the shift-lever. It only occurs from 1st to 2nd,2nd to 3rd and NEVER when downshifting. i feel the "punch" and then the gear goes in smoothly. Other than that it handles like a dream, no nasty noises whatsoever. Seller told me the clutch is changed about 5000kms ago when the rear oilseal was replaced. someone have any ideas? Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 15, 2013 Share Posted June 15, 2013 Do you have to put the clutch pedal all the way down to change gear? When was the gearbox fluid last checked/changed? Do you need to replace the shifter bushes? Quote Link to comment Share on other sites More sharing options...
Guest micke547 Posted June 15, 2013 Share Posted June 15, 2013 (edited) Hi I can change gear without pushing the clutch all the way to the floor. the gearbox fluid was changed at the same time the clutch and oilseal was changed at Lexus in Edinburgh. The shifter bushes is already replaced with aluminium ones. i have noticed i the problem dont seem to happen if i do like this when shifting 2nd gear->neutral or keep the clutch down->wait 1 sec->then go into 3rd i just got under the car to have a look, and i noticed there was some play in the propshaft somewhere around the center bearing, maybe that have something to do with it? Edited June 15, 2013 by micke547 (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest micke547 Posted July 8, 2013 Share Posted July 8, 2013 To everyone interested, the problem was pretty simple, I removed the propshaft and noticed that the big nut in the middle where the shaft is split was loose. So I greased the splines up, tightened the nut and both the slack and the punch I felt through the gear lever is now gone Quote Link to comment Share on other sites More sharing options...
