LOGIE Posted June 14, 2013 Share Posted June 14, 2013 Im in the middle of an NA-TT so my NA 1st cat has to go to make way for a decat, I've done a search and it seems most people just cable tie it up out the way as cutting it off turns on a warning light...Is this right? Also if it got damaged (should it get caught or fall down) how would I replace it as it comes through the underside of the car? Cheers Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 14, 2013 Share Posted June 14, 2013 cant you just plug it into your decat/downpipe mate? a hole is there already thats where mine is Quote Link to comment Share on other sites More sharing options...
LOGIE Posted June 14, 2013 Author Share Posted June 14, 2013 cant you just plug it into your decat/downpipe mate? a hole is there already thats where mine is I thought that mate, but I know the bolts are going to snap (rusty) and then how do I change it? it cant be taken off Quote Link to comment Share on other sites More sharing options...
ashbuster Posted June 14, 2013 Share Posted June 14, 2013 do you mean the sensor bolts that hold it in place? i replaced mine for stainless steel ones, if the old bolt snaps inside the decat then you would have to have it drilled out and re-threaded. i know some people use those easy out tools for some snapped bolts but ive never had any luck with them at all Quote Link to comment Share on other sites More sharing options...
