Steering lock engagement
nemesisjez
Hi everyone. I'm having a nightmare!!!!
Just fitted a new ignition barrel after having to drill out old one and to start with the steering
Lock would engage with key turned and would disengage when key was out. After removing
Barrel god knows how many times to try and find problem the steering lock will not engage
At all! I've looked down the hole where the barrel goes expecting to see some sort of pin but
Nothing there. I don't care if the steering lock won't engage but really worried it might while
I'm driving!!
Anyone got any ideas????? Going out of my mind here
Many thanks in advance
Jez
Edited by nemesisjez (see edit history)
Hey Keron
Somehow the the cam shaft between barrel and switch had turned 180 degrees and not pushed in far enough therefore steering lock on with ignition on and off when key out!
Anyway nightmare solved without much hassle
Really appreciate all your help.
Also dont suppose you have drivers side electric window mechanism do you? price?
Cheers
Jez
