EGT NPT sensor thread
Noz
What's recommended for this thread on the exhaust gas temperature bung welded on the manifold? NPT tape only goes to a couple hundred degrees. I'll hunt around for some loctite, but not sure that's going to be high enough either.
What's recommended?
Ok so by this I'm assuming a tapered thread would be considered to seal on it's own.
I work with NPT's all the time at work, and never heard of just using them to seal on their own. It would 100% leak with most gas low pressure applications, so I've never considered not using anything.
I'll just lube it up and ram it in :) Thanks for your help guys
