Mario’s ’93 hardtop SRD GT4202R build
Mario
There will be another one soon I believe ;), lovely car you have there Mario, Lee is doing a fantastic job as always, I bet you can't wait to collect it :D
I know Will ;)
- - - Updated - - -
Luc its a tripple carbon.
:cool:
  • Replies 167
Posted Images
  • 3 weeks later...
I like the oil cooler mounting. Does Lee sell the oil coolers as a standard kit with the mounting brackets and thermostatic take off plate etc?
Oil cooler is the SRD oil cooler kit, dont know if the brackets come with the kit though.
Rubber top mounts..not really understand what you mean by that, but they were on when first got the car back in aug 2009, these rubber caps can be pulled of by hand, give some form of protection me thinks, hope this answers your question.
@Jazz1 Some people might remove them as some suspension kits feature an Electronic Damping Force Controller known as EDFC, with these units installed the rubber plug can’t be fitted unless modified. I’m not 100% sure if the manually adjustable stick out that much that the plug needs removal cq modifying as well.
In my current set-up the plugs can be fitted ;-)
48603E PLUG, HOLE(FOR FRONT SUSPENSION SUPPORT RH)
90950-01659 1 $6.17
48609F PLUG, HOLE(FOR FRONT SUSPENSION SUPPORT LH)
90950-01659 1 $6.17
http://www.toyodiy.com/parts/p_J_1993_TOYOTA_SUPRA_JZA80-ALFQZ_4803.html
