Where does the "CRUISE" indicator be on a facelift TT?
Iky
  • 2 weeks later...
It was available on the Vertex/GS300 with the twin turbo engine, so in theory you could take all the gubbins from that and fit it. The facelifts use true flybywire throttle so I dont believe it needs a secondary throttle cable, but after that its all a bit unknown.
Now, if you can find a way to make it work I would be most interested as I love cruise (especially when managing the convoys, does anybody notice I cant keep a steady speed..). So if you can make it work then do shout!!
Looks Like I'm nearly there :)
Just unsure about the gearbox wiring but David P is kindly sending me out party of a loom that should help. Mines a pre-VVTI.
I see yours is a vvti from your signature if i'm correct. Don't know how much help I would be.
