Advice - RPS flywheel and pressure plate rebuild
Sheefa
Hi all
I managed to get a new 6 puck RPS clutch from Dusty @ MVP recently so fine there.
However, the RPS flywheel friction pads need replacing and I wondered if you can get them anywhere here or need to send the thing off for a rebuild in the USA? I have PM'd Dustry but surely someone here has had experience of these.
Also has anyone compared the RPS Pressure Plate to the OEM Pressure Plate. It looks IDENTICAL in every single way, no size differential, no design differential. It looks like RPS have just slapped a sticker on it. Which makes me think you should be able to use the stock OEM pressure plate with the RPS flywheel and 6 puck clutch?
Help.
Ta.
Greg
