Autobox up shift delays
viper
I'm currently running an Autobox with a 3600 hi stall.
Every run I make up the strip the box changes up late after bouncing off the limiter several times costing me valuable time up the strip.
Could anyone ahead some light on why this is happening?
Thanks
Dave
  viper said:
The box was removed and the seals replaced a few weeks ago along with the Toyota recommended fluid.
How so you raise the rev limit?
Thanks for the help
When the seals were replaced was the filter renewed?
What ECU are you running?
What diff wheel/tyre combo are you running? if the ECU isn't getting correct speed sensor info it can't do the correct things.
Edited by David P (see edit history)
I'm sorry I'm very new to autobox's I changed from manual to auto for drag purposes of the hi stall so I don't know much about them.
I don't think any filters where changed on the box when te seals where done. Is it a box off job to replace the filter?
Running a MAP 1 piggy back ecu.
Standard TT diff, was running MT streets 27x10x15
- - - Updated - - -
I should also mention manual mode doesn't work
bugger, ill have to get it done when its booked in for its MOT retest so might have to pay the toyota prices :(
- - - Updated - - -
Out of intrest, how will changing the strainer help with the gear changes?
(Copied and pasted from another thread to "complete the picture" and for anyone else who trips over this thread in the future.)
Birds eye view of a belly up T.T. auto box with pan removed, then just 3 bolts on the filter.
More pics in the link, yet this one shows enough for a filter change, :think: but you'd have known that already if you'd read my build thread. ;)
http://www.mkivsupra.net/vbb/showthread.php?233707-Project-Supracharger&p=3080115&viewfull=1#post3080115
