viper Posted June 9, 2013 Share Posted June 9, 2013 I'm currently running an Autobox with a 3600 hi stall. Every run I make up the strip the box changes up late after bouncing off the limiter several times costing me valuable time up the strip. Could anyone ahead some light on why this is happening? Thanks Dave Link to comment Share on other sites More sharing options...
LOGIE Posted June 9, 2013 Share Posted June 9, 2013 (edited) ATF fluid at the correct level? When was you oil strainer last changed? Edited June 9, 2013 by LOGIE (see edit history) Link to comment Share on other sites More sharing options...
David P Posted June 9, 2013 Share Posted June 9, 2013 If that doesn't fix it try raising the rev limit a little, if you haven't already. Link to comment Share on other sites More sharing options...
viper Posted June 9, 2013 Author Share Posted June 9, 2013 The box was removed and the seals replaced a few weeks ago along with the Toyota recommended fluid. How so you raise the rev limit? Thanks for the help Link to comment Share on other sites More sharing options...
mellonman Posted June 9, 2013 Share Posted June 9, 2013 Every time I have heard this it was always fluid Link to comment Share on other sites More sharing options...
David P Posted June 9, 2013 Share Posted June 9, 2013 (edited) The box was removed and the seals replaced a few weeks ago along with the Toyota recommended fluid. How so you raise the rev limit? Thanks for the help When the seals were replaced was the filter renewed? What ECU are you running? What diff wheel/tyre combo are you running? if the ECU isn't getting correct speed sensor info it can't do the correct things. Edited June 9, 2013 by David P (see edit history) Link to comment Share on other sites More sharing options...
Chris Bailey Posted June 9, 2013 Share Posted June 9, 2013 Any videos to show the problem? Link to comment Share on other sites More sharing options...
viper Posted June 9, 2013 Author Share Posted June 9, 2013 I'm sorry I'm very new to autobox's I changed from manual to auto for drag purposes of the hi stall so I don't know much about them. I don't think any filters where changed on the box when te seals where done. Is it a box off job to replace the filter? Running a MAP 1 piggy back ecu. Standard TT diff, was running MT streets 27x10x15 - - - Updated - - - I should also mention manual mode doesn't work Link to comment Share on other sites More sharing options...
LOGIE Posted June 9, 2013 Share Posted June 9, 2013 you just need to take the sump/oil pan off to change the filter. Link to comment Share on other sites More sharing options...
LOGIE Posted June 9, 2013 Share Posted June 9, 2013 id address the issue with Manu mode before anything else. Link to comment Share on other sites More sharing options...
David P Posted June 9, 2013 Share Posted June 9, 2013 This might be handy. http://www.mkivsupra.net/vbb/showthread.php?286709-Auto-trans-pan-filters&highlight=Auto+filters Link to comment Share on other sites More sharing options...
viper Posted June 9, 2013 Author Share Posted June 9, 2013 Iv checked the oil and its full Iv check the manual button and all wires seem connected Link to comment Share on other sites More sharing options...
David P Posted June 9, 2013 Share Posted June 9, 2013 First thing to do is to find out if a new filter was fitted and if not, fit one. Link to comment Share on other sites More sharing options...
viper Posted June 10, 2013 Author Share Posted June 10, 2013 Ok ill get it changed, but the item doesn't seem to be available anymore on the link and doesn't seem to have been re-listed. Link to comment Share on other sites More sharing options...
David P Posted June 10, 2013 Share Posted June 10, 2013 Find out first. Mr T hief charges about £75 for one of these, they can be had from the U.S. for less but you'll have to wait and be stung by Robbin Tax Hoods. Link to comment Share on other sites More sharing options...
viper Posted June 10, 2013 Author Share Posted June 10, 2013 bugger, ill have to get it done when its booked in for its MOT retest so might have to pay the toyota prices - - - Updated - - - Out of intrest, how will changing the strainer help with the gear changes? Link to comment Share on other sites More sharing options...
David P Posted June 10, 2013 Share Posted June 10, 2013 After the solenoids everything works by fluid pressure, clagged filter = lower pressure = dicky doings. Link to comment Share on other sites More sharing options...
David P Posted June 10, 2013 Share Posted June 10, 2013 Here. http://www.ebay.co.uk/itm/HASTINGS-FILTERS-TF134-Transmission-Filter-/281059350195?pt=Motors_Car_Truck_Parts_Accessories&hash=item41707156b3 Link to comment Share on other sites More sharing options...
viper Posted June 10, 2013 Author Share Posted June 10, 2013 Thanks for explaining that and for the link, i really appreciate it Link to comment Share on other sites More sharing options...
David P Posted June 10, 2013 Share Posted June 10, 2013 (Copied and pasted from another thread to "complete the picture" and for anyone else who trips over this thread in the future.) Birds eye view of a belly up T.T. auto box with pan removed, then just 3 bolts on the filter. More pics in the link, yet this one shows enough for a filter change, but you'd have known that already if you'd read my build thread. http://www.mkivsupra.net/vbb/showthread.php?233707-Project-Supracharger&p=3080115&viewfull=1#post3080115 Link to comment Share on other sites More sharing options...
viper Posted June 10, 2013 Author Share Posted June 10, 2013 Thanks davep Ill get this done by THor when they re MOT the car as i dont want to do it on axel stands Link to comment Share on other sites More sharing options...
JasonR24 Posted June 14, 2013 Share Posted June 14, 2013 Sorry for the off topic but did you change the engine and dash wiring harness when you went from a manual to auto? As my engine harness is from a manual but everything else is auto? Link to comment Share on other sites More sharing options...
