scott87 Posted June 10, 2013 Share Posted June 10, 2013 If you use big red be careful as i have seen a seal kit with horrible retainer rings in it which i personally wouldn't use. Didnt know that. MR2 ones i had were good quality. I shall look out for this when i refurb my callipers this winter! Quote Link to comment Share on other sites More sharing options...
trebor69 Posted June 10, 2013 Share Posted June 10, 2013 I tried ....in vain .......to get the o/s front disc off using the bolts in the holes but they ended up stripping the thread from the disc .......so I just lubed all the caliper parts up and fitted pads ........I will get it off eventually but prob not without heat Hope you have better luck Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 11, 2013 Share Posted June 11, 2013 Didnt know that. MR2 ones i had were good quality. I shall look out for this when i refurb my callipers this winter! Someone on here bought their kit and the retainer rings looked awful, i think they said they would replace them though. Being rather anal when it comes to parts like this i prefer to use O/E and know what i've got is 100 % as it should be. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted June 12, 2013 Author Share Posted June 12, 2013 I tried ....in vain .......to get the o/s front disc off using the bolts in the holes but they ended up stripping the thread from the disc .......so I just lubed all the caliper parts up and fitted pads ........I will get it off eventually but prob not without heat Hope you have better luck My front discs are coming off whether they want to or not! Quote Link to comment Share on other sites More sharing options...
Big Mark Posted June 15, 2013 Author Share Posted June 15, 2013 All parts brought except brake bleeder and fluid. Can anyone recommend either? Unfortunately I've had a couple of large unexpected bills in the last couple of days so have to watch the pennies, plus the car is never going on a track, so I know some will recommend RBF 600 but at £25 per litre I'm thinking either http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_204323_langId_-1_categoryId_255218 Or http://www.opieoils.co.uk/p-69377-gulf-racing-brake-fluid-dot-51.aspx Quote Link to comment Share on other sites More sharing options...
berg Posted June 15, 2013 Share Posted June 15, 2013 The gunson eezibleed kit you posted the link to is a good bit of kit Used mine to do a full fluid change on my own in 15 mins and that was doing all 4 corners, they are well worth the money *just have someone on stand by to watch the bottle doesnt go empty otherwise its back to square one ;-) Quote Link to comment Share on other sites More sharing options...
Big Mark Posted June 15, 2013 Author Share Posted June 15, 2013 The gunson eezibleed kit you posted the link to is a good bit of kit Used mine to do a full fluid change on my own in 15 mins and that was doing all 4 corners, they are well worth the money *just have someone on stand by to watch the bottle doesnt go empty otherwise its back to square one ;-) I wasn't sure if this would fit a supra or not so have just bought this: http://www.ebay.co.uk/itm/200756420457?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 After watching this clip. Looks very easy. http://video.advanceautoparts.com/?v=10786 Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 15, 2013 Share Posted June 15, 2013 Ask Ian C which vacuum bleeder he bought not too long ago, the best and easiest way to bleed the brakes Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 15, 2013 Share Posted June 15, 2013 http://www.mkivsupra.net/vbb/showthread.php?274740-Long-brake-pedal-after-a-couple-of-hard-stops Post number 9 Quote Link to comment Share on other sites More sharing options...
Big Mark Posted June 15, 2013 Author Share Posted June 15, 2013 http://www.mkivsupra.net/vbb/showthread.php?274740-Long-brake-pedal-after-a-couple-of-hard-stops Post number 9 Looks identical to what I've just bought. Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 16, 2013 Share Posted June 16, 2013 It's the absolute business. One trick you will need, though, is once you've got the hose on and vacuum built up and everything ready, slather a load of grease around the bleed nipple before cracking it open. Cover the hose end and the threads, then when you open it you don't suck in air from those two places and make it look like there is still air in the brake system. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted June 16, 2013 Author Share Posted June 16, 2013 Thanks for the tip! Quote Link to comment Share on other sites More sharing options...
Caesard Posted June 16, 2013 Share Posted June 16, 2013 Also the Gulf brake fluid 5.1 is brilliant too. I have it on mine with braided lines and full Chris Wilson pads, and it is working brilliantly. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted June 16, 2013 Author Share Posted June 16, 2013 Thanks for the review, I've just ordered 2 litres from Opieoils, but the website wouldn't accept the discount codes I have. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted June 22, 2013 Author Share Posted June 22, 2013 (edited) All done, thanks for the tips people. Pins were a bit of an issue but as I was painting the calipers it was easier to take off the whole caliper and drive the pins out on a flat service. The only big issue was removing the old rear hoses as they really didn't want to seperate from the solid lines. A huge thank you to Girth45 who popped by and saved the day. I owe you one! Edited June 22, 2013 by Big Mark (see edit history) Quote Link to comment Share on other sites More sharing options...
girth45 Posted June 22, 2013 Share Posted June 22, 2013 No problem mate, we will have to have a few beers. Quote Link to comment Share on other sites More sharing options...
