Removing air con system.
Suprakeith
Can someone point us to a guide please or any information on removing the air con system on n/a supra please, did try the search bar but couldnt find anything. Just trying to tidy engine bay up and remove parts dont want and need. Am going to sort water hoses when new radiator and silcone hoses turn up. Plus going to remove the carcoal canister aswell.
I think you will find the shorter belt catchs against the A/C pulley if you don't remove it
It's easy enough to do, I did mine, I had issues getting the bracket off the front of my A/C see here
This shows the bracket you need to remove here
And there is a helpful exploded diagram here of how it should come apart
Didn't Kaan take his aircon out on his build, maybe worth a pm mate.
I sure did mate.
Basically just unbolt everything taking the condensater and pump out and then you will need a shorter aux belt, PK 1865 iirc. Job done :)
I sure did mate.
Thanks mate, will proberly pm you when come to doing the pump part and getting smaller belt but will just remove all other bits 1st
:think:
Out if interest is there any benefit of removing the aircon? Or is it just for weight?
One less ancillary for the engine to turn. Probably next to no real world difference but I've removed it to keep the bay that bit tidier and on the basis of every little bit helps (horsepower and weight).
Any chance you have the bits still and want a new home for them?
The air con pump has been stripped so I could reuse the bracket and I have promised the condenser to Girth45. The rest isn't worth keeping as I had to bend the pipes a little to remove them, they're only good for scrap now really.
No worries. Ive got a leak somewhere, but i assume its the condensor rather than the piping. Will have to hope someone else has a condensor that needs a new home :)
When i remove mine if its in good condition your welcome to it, proberly wont be removing air con bits till next weekend as doing some bits on brothers m3 sunday :)
That would be great thanks. Yer any bits you remove that you dont want ill take :) Really want cold air in the car again.....
