Crash/airbag sensor on mums focus
Suprakeith
My mum has got light on warning light on dash so had it diaganosed and they said was front airbag sensor.
So had look today and think have found the correct sensor,just want to get peoples advice if am right or wrong. Its a 53 plate 1.6 petrol focus. And help would be great as want to get it sorted for her asap. Here is couple pictures of suspect sensor
I found the sensor in the radiator fan shroud. Havent a clue where to look for crash sensor as took all lights and grill off and couldnt find any wires going to front of car
To be honest mate, and I don't mean this in a horrible or condescending way, bit if yoy "haven't got a clue" as you put it, should you really be dealing with airbag systems?
It should be bolted to the offside front chassis rail iirc. These are common for the module failing aswell, which gives a code relating to the front sensor.
Will have their when get chance to look at mums car next. And i should be ok all want to do is find where sensor is and see what it looks like so can order new one and replace it for her, when do that will disconnect the battery for sure. Just do need to find sensor 1st as they list a few for mums car and want to make sure get right part
