That_Supra_Guy Posted June 7, 2013 Share Posted June 7, 2013 Hi lads, just noticed whilst giving my idle control valve a clean that the area around the valve cover/head seal has a coat of dirty oil (seems reasonably fresh, although its pretty thick, no drips and covered with plenty of dust and usual crap) surrounding the entire head. Would I be right in saying thats the cover seal(s) had it? Or is there something else I need to be worrying about? Its a 93 jap spec NA. I'll fire up some photos if needed. Cheers guys. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted June 7, 2013 Share Posted June 7, 2013 For what they cost and the time it takes to replace the gaskets its worth doing even if its a small leak. It could have been over tightened at some point or not tightened in the correct pattern. Im sure Whifbitz sells the gaskets seperatly quite cheap. Quote Link to comment Share on other sites More sharing options...
David P Posted June 7, 2013 Share Posted June 7, 2013 Before tearing it apart try nipping them up first, 7 lbft I believe. Quote Link to comment Share on other sites More sharing options...
That_Supra_Guy Posted June 7, 2013 Author Share Posted June 7, 2013 For what they cost and the time it takes to replace the gaskets its worth doing even if its a small leak. It could have been over tightened at some point or not tightened in the correct pattern. Im sure Whifbitz sells the gaskets seperatly quite cheap. Yeah I figured it'd probably be worth doing anyways! Cheers for the heads up, ill go check whifbitz out.... Quote Link to comment Share on other sites More sharing options...
That_Supra_Guy Posted June 7, 2013 Author Share Posted June 7, 2013 Before tearing it apart try nipping them up first, 7 lbft I believe. I'll be stealing a torque wrench tomorrow to do just that, I've heard they can be easily overtightened all the same so probably worth a change, its something new to learn atleast. Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 7, 2013 Share Posted June 7, 2013 The seals go rock hard with age/mileage so for what they cost just replace them. Quote Link to comment Share on other sites More sharing options...
That_Supra_Guy Posted June 7, 2013 Author Share Posted June 7, 2013 The seals go rock hard with age/mileage so for what they cost just replace them. Yeah I will do, you wouldn't happen to know where to get a hold of a set by chance? Something a toyota dealer could order? I'm new to older cars see :L Quote Link to comment Share on other sites More sharing options...
Kaan W Posted June 7, 2013 Share Posted June 7, 2013 Yeah I will do, you wouldn't happen to know where to get a hold of a set by chance? Something a toyota dealer could order? I'm new to older cars see :L Whifbitz as mentioned earlier Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 7, 2013 Share Posted June 7, 2013 What Id do is clean everything up first, and see if anything else leaks out. Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 7, 2013 Share Posted June 7, 2013 Yes Toyota can get them no problem and there not that much for genuine parts. It would pay to check if the NA uses the washers with seals fitted to them and if so replace these at the same time. Quote Link to comment Share on other sites More sharing options...
That_Supra_Guy Posted June 7, 2013 Author Share Posted June 7, 2013 Whifbitz as mentioned earlier £40 posted from whifbitz..... surely that's a little steep for two rubber gaskets? or is the £15 shipping a direct from Japan job? Quote Link to comment Share on other sites More sharing options...
That_Supra_Guy Posted June 7, 2013 Author Share Posted June 7, 2013 It would pay to check if the NA uses the washers with seals fitted to them and if so replace these at the same time. Yeah I'll need to do a little digging on that one, I read another chap discussing the same seals somewhere else on the interweb...pretty sure the pre-vvti ones don't use them though... could be wrong. Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 7, 2013 Share Posted June 7, 2013 £40 posted from whifbitz..... surely that's a little steep for two rubber gaskets? or is the £15 shipping a direct from Japan job? £15 for postage ? Try your local Toyota dealer mate Quote Link to comment Share on other sites More sharing options...
That_Supra_Guy Posted June 7, 2013 Author Share Posted June 7, 2013 £15 for postage ? Try your local Toyota dealer mate You're not wrong there! Quote Link to comment Share on other sites More sharing options...
Kaan W Posted June 8, 2013 Share Posted June 8, 2013 Pm Paul directly dude, it will only be a few quid. Quote Link to comment Share on other sites More sharing options...
That_Supra_Guy Posted June 8, 2013 Author Share Posted June 8, 2013 Pm Paul directly dude, it will only be a few quid. Have done man, cheers for the heads up! Quote Link to comment Share on other sites More sharing options...
Kaan W Posted June 8, 2013 Share Posted June 8, 2013 Have done man, cheers for the heads up! Thats cool, glad I could help! Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted June 8, 2013 Share Posted June 8, 2013 It's just a site pre set postage, it said that to me before for some gearshift bushes and a quick pm to Paul and he sold me the item cheaper and the postage was sod all too. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted June 8, 2013 Share Posted June 8, 2013 I couldnt remember why lol. Quote Link to comment Share on other sites More sharing options...
jasooon Posted June 8, 2013 Share Posted June 8, 2013 hi just had mine done and they cost me twenty quid from a local motor factor Quote Link to comment Share on other sites More sharing options...
