Homer Posted June 6, 2013 Share Posted June 6, 2013 I'm now 99% certain that the diff I have is a TRD one, but reading on SF it seems there is a specific "TRD" oil these need. Is that correct? Link to comment Share on other sites More sharing options...
Samurai 20V Posted June 6, 2013 Share Posted June 6, 2013 Been researching this as I have a TRD diff to fit.. I believe any 75W-140 LSD oil will suffice, Lee P recommended Millers... Shell and Castrol make similar in my country, I was going to try the Shell Spirax.. TRD do have a special oil, but it would cost alot to ship from Japan.. Link to comment Share on other sites More sharing options...
Camry5Sgte Posted June 6, 2013 Share Posted June 6, 2013 I use Royal purple in mine and have had no probs for just about a year now since it was installed. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted June 6, 2013 Share Posted June 6, 2013 http://www.opieoils.co.uk/p-1023-red-line-heavy-shockproof-gear-oil-75w-140.aspx Top Gear! I have a TRD LSD in mine, no chatter unless i'm reversing at full lock when the diff is stone cold, then it's minimal. Link to comment Share on other sites More sharing options...
Homer Posted June 6, 2013 Author Share Posted June 6, 2013 Thanks guys, I was about to buy GL3 75/90 as that's what a number of people have recommended. To help my understanding, why would 75/140 be needed for this diff type over 75/90? I understand the GL5 rating of the 75/140 is for heavy duty use, but this is going in an NA 5spd I'll go purchase the 75/140 anyway Link to comment Share on other sites More sharing options...
Samurai 20V Posted June 7, 2013 Share Posted June 7, 2013 Actually Homer, sorry, meant to type 85W-140.. Here is the TRD & Shell Link.. http://www.trdparts.jp/english/parts_lsd-oil.html http://www.epc.shell.com/Docs/GPCDOC_GTDS_Shell_Spirax_S2_A_85W-140_(en)_TDS_v1.pdf Link to comment Share on other sites More sharing options...
Homer Posted June 9, 2013 Author Share Posted June 9, 2013 Thanks mate, just placed an order for some of the stuff The Turtleshead mentioned. 2nd question though, I'm trying to find the correct sealant for the carrier cover. Toyota wanted £69 for their one!! Is there an off the shelf alternative? Link to comment Share on other sites More sharing options...
LOGIE Posted June 9, 2013 Share Posted June 9, 2013 I use this stuff for all oil based sealants, ie sumps,diffs, etc Link to comment Share on other sites More sharing options...
TheTurtleshead Posted June 9, 2013 Share Posted June 9, 2013 Thanks guys, I was about to buy GL3 75/90 as that's what a number of people have recommended. To help my understanding, why would 75/140 be needed for this diff type over 75/90? I understand the GL5 rating of the 75/140 is for heavy duty use, but this is going in an NA 5spd I'll go purchase the 75/140 anyway As I understand it the viscosity changes with heat… It will only ever hit 140 or close if you're really abusing it! Otherwise it acts like a thinner oil. Mine has been buttery smooth on that stuff, I wouldn't use anything else now tbh, it seems to work really well. Link to comment Share on other sites More sharing options...
Homer Posted June 11, 2013 Author Share Posted June 11, 2013 Nice one, thanks gents Link to comment Share on other sites More sharing options...
DJT88 Posted June 12, 2013 Share Posted June 12, 2013 I've been doing some reading up on oil values the other day. The 140 stuff will stay thicker when warm compared to 95. The 85W is the value for when its cold. But I think you have to see them seperately(so its not thinner when cold because 85W is lower than 140. It's two different ranges) The higher the value the thicker it gets. W-value : when cold Second value: at operating temperature. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted June 12, 2013 Share Posted June 12, 2013 75w150 definately, we use the Motul range of fluid, top notch. Link to comment Share on other sites More sharing options...
