oil presure/ oil temp
girth45
Hi just fitted a prosport digital guages oil press/oil temp
can someone give me some figures i should be seeing , cold/hot and under load, i ask because cold fire up pressure guages reads 110, if its psi seems high, if its kpa = 15 psi, cant find any info, just need some figures to compare to, hope someone can help. cant even find info on what scale ther reading in! bought on the forum used.
:D
The hot & cold pressures seem about right. Mine certainly settles back to about 30psi @ tickover when warm.
If the temp is reading in Farenheit (sp?) then thats ok too. 160F equates to about 71C.
The recommended location for the temp sensor is the sump.
However, if the gauge is already reading in Celcius, you have a problem.
