billy0090 Posted June 3, 2013 Author Share Posted June 3, 2013 i will call round a few local garages tomorrow to see if they do the Sniff test, Link to comment Share on other sites More sharing options...
Scooter Posted June 3, 2013 Share Posted June 3, 2013 Post up a pic of the underside of your actual rad cap...does the rubber base look perished at all? does it have a firm'ish spring when pushed by hand? Link to comment Share on other sites More sharing options...
Dnk Posted June 4, 2013 Share Posted June 4, 2013 Just to add before i did anything else i'd fit a new rad cap from Toyota and top up the expansion tank and see if you still have the problem. Does the heater blow out hot air on the max hot setting ? Link to comment Share on other sites More sharing options...
billy0090 Posted June 4, 2013 Author Share Posted June 4, 2013 Just to add before i did anything else i'd fit a new rad cap from Toyota and top up the expansion tank and see if you still have the problem. Does the heater blow out hot air on the max hot setting ? Ok the heaters do blow hot. Can't take pic of cap yet. I just had a block test done and the notes say "Just starting to change fluid colour,possible head gasket fault" Isit stil worth me changing cap/ therm and rad or is this pointless? Thanks Link to comment Share on other sites More sharing options...
Rummy Posted June 4, 2013 Share Posted June 4, 2013 For the sake of 130-50 quid for an after market rad and stat I'd say its better than another engine or head refurb if the HG hasn't definitely failed. Link to comment Share on other sites More sharing options...
Scooter Posted June 4, 2013 Share Posted June 4, 2013 Billy don't panic or rush anything...... Get a rad cap, the rad caps are not supra specific they are shared with lots of 'normal' Toyotas and a local autofactor will have a good enough one for the time being. Get some coolant that matches what is already in there ie blue or red and fill the expansion tank to the max. Go out for a local drive, a loop that doesn't ever leave you far from home! If the needle rises get home and turn it off and observe the rad and expansion tank. If the cap doesn't fix it then you might have a tiny rad leak etc.....unless someone has driven it for a while with the water temp high then the head gasket should be ok, certainly worth doing the above before chucking it at a garage. Link to comment Share on other sites More sharing options...
Dnk Posted June 4, 2013 Share Posted June 4, 2013 Billy don't panic or rush anything...... Get a rad cap, the rad caps are not supra specific they are shared with lots of 'normal' Toyotas and a local autofactor will have a good enough one for the time being. Get some coolant that matches what is already in there ie blue or red and fill the expansion tank to the max. Go out for a local drive, a loop that doesn't ever leave you far from home! If the needle rises get home and turn it off and observe the rad and expansion tank. If the cap doesn't fix it then you might have a tiny rad leak etc.....unless someone has driven it for a while with the water temp high then the head gasket should be ok, certainly worth doing the above before chucking it at a garage. Link to comment Share on other sites More sharing options...
billy0090 Posted June 4, 2013 Author Share Posted June 4, 2013 Billy don't panic or rush anything...... Get a rad cap, the rad caps are not supra specific they are shared with lots of 'normal' Toyotas and a local autofactor will have a good enough one for the time being. Get some coolant that matches what is already in there ie blue or red and fill the expansion tank to the max. Go out for a local drive, a loop that doesn't ever leave you far from home! If the needle rises get home and turn it off and observe the rad and expansion tank. If the cap doesn't fix it then you might have a tiny rad leak etc.....unless someone has driven it for a while with the water temp high then the head gasket should be ok, certainly worth doing the above before chucking it at a garage. Thanks.... I have ordered a rad cap and thermostat from Steve at Oxford Toyota who gave me some good discount for being on here. Any ideas on costs of a radiator for an auto ... Dealers price is 341.58 Not sure what to look for on eBay :/ Link to comment Share on other sites More sharing options...
jimwire Posted June 4, 2013 Share Posted June 4, 2013 I got an ASI alluminium rad off ebay and it fit really well. Might be worth a look. Is the car auto or manual? Link to comment Share on other sites More sharing options...
Rummy Posted June 4, 2013 Share Posted June 4, 2013 (edited) I second the fleabay option. 130£ will get you a decent after market (no name) Ali rad. I had no problems with the one I had. Something like this http://bit.ly/10W4ANT Edited June 4, 2013 by Rummy (see edit history) Link to comment Share on other sites More sharing options...
gavin.starr Posted June 4, 2013 Share Posted June 4, 2013 I had a similar issue with mine when i first got mine. It turned out that the rad cap was old and knackered and filled up the expantion tank and then steam from the rad was bubbling up through the expantion tank. I replaced flushed the system replaced my thermostat, and the rad cap and that sorted it out until 2 weeks later the top of my original rad exploded all over my engine bay, was not impressed. So i then ended up buying a koyo rad to replace it with. Link to comment Share on other sites More sharing options...
billy0090 Posted June 4, 2013 Author Share Posted June 4, 2013 its auto GZ model import, which is why im not sure on what rad to get as i believe it has a built in oil cooler as well according to the dealer ?? if some one could point one out to me.... ive found loads but i dont know if mines JZA80 ? Link to comment Share on other sites More sharing options...
Swampy442 Posted June 4, 2013 Share Posted June 4, 2013 Dont worry about rads yet, start cheap and small, cap first. Link to comment Share on other sites More sharing options...
billy0090 Posted June 6, 2013 Author Share Posted June 6, 2013 rad cap should be with me tomorrow, fingers crossed that solves it ! il keep you updated! Link to comment Share on other sites More sharing options...
ashbuster Posted June 6, 2013 Share Posted June 6, 2013 i had that noise when my rad cap was buggered, letting air in Link to comment Share on other sites More sharing options...
billy0090 Posted June 7, 2013 Author Share Posted June 7, 2013 Ok guys I've fitted new rad cap. Still over heats when driven enthusiastically Link to comment Share on other sites More sharing options...
dan294 Posted June 7, 2013 Share Posted June 7, 2013 Might be worth taking the rad off and flushing it maybe? If it's partially blocked, that won't help. Link to comment Share on other sites More sharing options...
dan294 Posted June 7, 2013 Share Posted June 7, 2013 Just a thought, and I'm probably miles off, but is your viscous fan working OK? Link to comment Share on other sites More sharing options...
billy0090 Posted June 7, 2013 Author Share Posted June 7, 2013 The fans work fine. And I have a rad flush Nd therm renewal booked for Wednesday. The heat rise is pretty sudden driving normally temp gauge in the middle then put my foot down for a mile and you can see the temp gauge getting higher Link to comment Share on other sites More sharing options...
Rummy Posted June 7, 2013 Share Posted June 7, 2013 I'm pretty sure a new stat will sort your problem mate. Link to comment Share on other sites More sharing options...
billy0090 Posted June 7, 2013 Author Share Posted June 7, 2013 ifit was a stat? the top pipe coming off the radiator would not get hot ?...... when you squeeze that pipe you can feel pressure..... ive been told thats not good ? Link to comment Share on other sites More sharing options...
monsween Posted June 8, 2013 Share Posted June 8, 2013 I've had the exact same overheating problem (no bubbling mind you) It started to happen after I fitted a FMIC. New rad and its been fine ever since. I did replace the cap first as well. Link to comment Share on other sites More sharing options...
billy0090 Posted June 8, 2013 Author Share Posted June 8, 2013 ok , thanks for all your advise. I have it booked for a radiator flush and a thermostat renewal next week, ive told them to inspect for any leaks. Il post again once its been done. Link to comment Share on other sites More sharing options...
billy0090 Posted June 12, 2013 Author Share Posted June 12, 2013 hey guys, had my thermostat fitted today and a coolant flush took for a short test drive all ok so far! but when i parked on my drive i had loads of steam coming from under my bonnet........ looked like i have pope a hose :/ does any one know the part numbers for these 2 hoses so i can order from dealer! cheers Billy Link to comment Share on other sites More sharing options...
Scooter Posted June 12, 2013 Share Posted June 12, 2013 I have the silver pipework from a tt in the garage and some of the ends have the rubber pipes still on. Sod's law says these don't but i'll check for you. Link to comment Share on other sites More sharing options...
