No Boost pressure reading
Rummy
Hi all
Just took the Supe (BL T67 dbb single) for a spin then just as it came into boost, the car jolted as if starved of fuel and the BOV (HKS SSQ) no longer flutters but makes a horrible dull droning noise.
There is also no boost pressure readings on either of my gauges (greddy analogue and Blitz SBC ID3). I checked the lines going into the boost control box and BOV and all are ok. I took the control box inlet hose off and blew in it whilst recording on the Blitz. It registered a little pressure each time on the recording so am I right in assuming the problem is in the BOV (valve stuck?) as it's no longer releasing pressure to the control box?
It just sounds like it's releasing through the intake...
Cheers
Mike
Right, had a look at the hoses and they're all still connected with no splits present. I've checked the clamps too. I guess the next step is a pressure test. As said in my OP could the BOV be at fault stuck open? The only reason I say this is when I come off throttle it no longer flutters but makes a dull continuous noise similar to a kazoo!
Or perhaps the Blitz solenoid box?
Another easy thing to check would be to remove the intake pipe and check the compressor wheel and make sure it is turning freely.
That was my next thing on the list. It turned fine by hand but Will check with motor running next.
