Andrew K Posted September 30, 2014 Author Share Posted September 30, 2014 tell you what is a nice touch... the double USB points in the cigarette lighter socket..... spill? where did you get the bits for that as I'm going to do it I got the USB adaptor i have from Amazon and also an extension cable as the ones that come with I-phones are a bit short! Quote Link to comment Share on other sites More sharing options...
Andrew K Posted September 30, 2014 Author Share Posted September 30, 2014 When I did the rear lights the wiring was more to do with the fog light side of things which I copied from the forum, doing this aloud me to get the original brake light format back. Quote Link to comment Share on other sites More sharing options...
Andrew K Posted October 9, 2014 Author Share Posted October 9, 2014 Weekend just gone i made a start on fitting my top secret gauge pod holder, got both upper and lower glove boxes removed and then offered up the gauge holder to see what the fitment was like! well as you will see from the picture i wasn`t to happy as there was a massive gap along the top edge! after a bit of cursing as i`ve been waiting ages for this to turn up! and the fit is rubbish i decided to get the fibre glass kit out so i could build up the area on the gauge pod that wasn`t level with the dash, sanded it back till it was and then put some filler on, it`s now finish sanded and ready for painting and the fit is 100 times better than it was. Quote Link to comment Share on other sites More sharing options...
supersizejim Posted October 9, 2014 Share Posted October 9, 2014 Nice job tidy! Quote Link to comment Share on other sites More sharing options...
Kev.O Posted October 9, 2014 Share Posted October 9, 2014 Well worth the effort, well done. Quote Link to comment Share on other sites More sharing options...
Andrew K Posted October 9, 2014 Author Share Posted October 9, 2014 Nice job tidy! Thanks Well worth the effort, well done. Yeah your right there mate cheers. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 9, 2014 Share Posted October 9, 2014 Nicely done Andrew. Quote Link to comment Share on other sites More sharing options...
Andrew K Posted October 9, 2014 Author Share Posted October 9, 2014 Nicely done Andrew. Thanks Luc, Was a messy job but looks loads better now Quote Link to comment Share on other sites More sharing options...
Andrew K Posted October 10, 2014 Author Share Posted October 10, 2014 Gauge pod only has a primer coat at the moment but will be spraying it with some black plasti-dip so looks more at home with everything else, offered it up to test the fit with the dash and think it now looks loads better. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted October 10, 2014 Share Posted October 10, 2014 Looks loads better, massive improvement good job! Quote Link to comment Share on other sites More sharing options...
Guest Nicholas Posted October 10, 2014 Share Posted October 10, 2014 Did someone say double USB ports? Good work Andrew. Quote Link to comment Share on other sites More sharing options...
suomipoika Posted October 10, 2014 Share Posted October 10, 2014 Good work! Looks so much better now! Quote Link to comment Share on other sites More sharing options...
Andrew K Posted October 10, 2014 Author Share Posted October 10, 2014 Thanks guys, wasn't looking forward to the hassle of doing it but glad I did now. Quote Link to comment Share on other sites More sharing options...
Andrew K Posted November 13, 2014 Author Share Posted November 13, 2014 Finally got my top secret gauge pod holder painted and fitted to the car, i decided not to use the plasti-dip as i`ve noticed that the panel under my stereo which is seem`s to mark quite easy! so gave the gauge pod holder a coat of satin black spray paint and think it turned out looking pretty good All the gauges are linked to the control unit, its now ready for when it goes in to SRD to have the engine fitted and all sensors connected up. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted November 14, 2014 Share Posted November 14, 2014 Wow ... that looks super clean. Quote Link to comment Share on other sites More sharing options...
Brodierx7 Posted November 14, 2014 Share Posted November 14, 2014 That's one hell of a tidy build! I want that spark plug cover! Quote Link to comment Share on other sites More sharing options...
Andrew K Posted November 14, 2014 Author Share Posted November 14, 2014 Wow ... that looks super clean. Thanks That's one hell of a tidy build! I want that spark plug cover! Cheers, been after one of those Lexan spark plug covers for flipping ages! So this one won't be leaving my possession for a loooooooong time. Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted November 16, 2014 Share Posted November 16, 2014 Love the interior; that looks very smart and fresh. Quote Link to comment Share on other sites More sharing options...
Andrew K Posted February 12, 2015 Author Share Posted February 12, 2015 Not much of an update but i purchased a new throttle cable bracket that mounts to the side of the cam cover. I was also in need of the throttle cable bracket that mounts to the master cylinder but Toyota have discontinued these now! luckily i had a rummage through all the parts i have out in the garage and managed to find an old one I pulled the old tired black coating of and gave the hole bracket a clean up with a bead blaster which got it looking all nice and new, then i dipped the end in a tin of black plasti-dip i had bought to give it the nice rubber protective coating again, wasnt to sure about this but turned out ok for the little job it was. Quote Link to comment Share on other sites More sharing options...
Andrew K Posted February 12, 2015 Author Share Posted February 12, 2015 (edited) Getting a bit stuck for things to do myself now as the rest will be done and fitted by SRD been speaking to Lee and he`s ordered some parts in for me so everything is in house ready for when my car goes to them, parts are :- Aeromotive FPR kit, spec stage 1 clutch, hard pipe kit for the intercooler, HKS dump valve, Boost control solenid, Walbro 485 fuel pump. that should pretty much be all the parts as i have the rest so now looking forward to getting this underway Edited February 12, 2015 by Andrew K (see edit history) Quote Link to comment Share on other sites More sharing options...
Luxluc Posted February 13, 2015 Share Posted February 13, 2015 I may have missed it Andrew, but are you still on the 6765 turbo? What IC pipes are you going for 2.5" or 3"? Quote Link to comment Share on other sites More sharing options...
Andrew K Posted February 13, 2015 Author Share Posted February 13, 2015 I may have missed it Andrew, but are you still on the 6765 turbo? What IC pipes are you going for 2.5" or 3"? Yes I'm still using the Precision T6765 turbo. Not sure what size the IC pipes will be, asked Lee for a hard pipe kit to go with my CW SMIC but I'm sure Lee will use the correct size needed. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted February 13, 2015 Share Posted February 13, 2015 Ok. Didn't see that you went for a SMIC. Quote Link to comment Share on other sites More sharing options...
Andrew K Posted February 13, 2015 Author Share Posted February 13, 2015 Ok. Didn't see that you went for a SMIC. Wanted to keep the working front active spoiler so decided to go with the CW SMIC, I've read and heard good things about these and they can handle up to 600bhp which is the max I'd like to go anyway, if it's to restrictive I'll have to go the other route and fit a FMIC and do away with the OEM active spoiler Quote Link to comment Share on other sites More sharing options...
Luxluc Posted February 14, 2015 Share Posted February 14, 2015 I think Chris' SMIC should easily be good for 600 bhp. Iirc, Bignum was running a SMIC on his old 67mm turbo ; even beating it though the Nurgburgring was fine. Quote Link to comment Share on other sites More sharing options...
