Andrew K Posted March 12, 2017 Author Share Posted March 12, 2017 Since the Supra has been parked up over the winter months it has given me some time to do a few of the jobs i`ve been wanting to do, when i put the UK Spec bonnet on with the air scoop i`ve always intended to put the under bonnet air diverter on pictured below. But as i have a Cusco strut brace on the car it is impossible to have the air diverter above fitted to the underside of the bonnet as it fouls the strut brace As i would never be happy just leaving it off i bought myself some sheet Aluminium and got creative and made my own i got all the parts required cut out and took it to my local sheet metal fabricator and had them weld it all in place, when i got it back i gave it a few coats of VHT Black paint and its now ready to be fitted once the plastic fittings i`ve ordered turn up. Link to comment Share on other sites More sharing options...
Andrew K Posted March 12, 2017 Author Share Posted March 12, 2017 (edited) The next job was to tackle the cam covers! a few years ago now i had them powder coated and now they`ve been on the car it`s had a horrible reaction and started to blister up due to heat and what ever else that might have caused this so as it looked a total eye sore i took them off and started the tedious job stripping the powder coating off! After a day or two doing this i wish i had never got them powdered coated lesson learned the hard way i suppose but once stripped i will be having them painted this time. Finally after five days i got it all stripped off and also decided to grind down the horrible casting edge you get on the lower edge of the cam covers. I`m now going to get them Bead blasted to give them a good thorough clean and they will then be getting painted. Edited March 13, 2017 by Andrew K (see edit history) Link to comment Share on other sites More sharing options...
bayside_supra Posted March 12, 2017 Share Posted March 12, 2017 Nice work on the air diverter. I just sprayed my cam covers in vht engine paint. Really easy to do and came up great. I used the vht primer and lacquer as well. They do a few colours. Link to comment Share on other sites More sharing options...
Andrew K Posted March 12, 2017 Author Share Posted March 12, 2017 Nice work on the air diverter. I just sprayed my cam covers in vht engine paint. Really easy to do and came up great. I used the vht primer and lacquer as well. They do a few colours. https://uploads.tapatalk-cdn.com/20170312/321d73f835bb0e9f4591037eb07debab.jpg /QUOTE] Thanks Bud Done a good job on your cam covers, may look into doing mine like that as well if there's a choice of different colours. What make of VHT paint did you use as there's quite a few different makes? Link to comment Share on other sites More sharing options...
CarlM Posted March 12, 2017 Share Posted March 12, 2017 Nice work on the air diverter. I just sprayed my cam covers in vht engine paint. Really easy to do and came up great. I used the vht primer and lacquer as well. They do a few colours. https://uploads.tapatalk-cdn.com/20170312/321d73f835bb0e9f4591037eb07debab.jpg /QUOTE] Look great, looking forward to doing mine too [emoji4] Link to comment Share on other sites More sharing options...
bayside_supra Posted March 13, 2017 Share Posted March 13, 2017 I used the VHT engine metallic as well as the high temp primer and lacquer. Mine is the titanium silver blue, it would be cool to see one of the other colours. The black pearl looks nice, I was considering that one. http://www.vhtpaint.com/high-heat/vht-engine-metallic Link to comment Share on other sites More sharing options...
Andrew K Posted March 24, 2017 Author Share Posted March 24, 2017 Plastic fixings i`ve been waiting for recently arrived in the post, also managed to find a place close to my work that got me some M6 stainless steel nuts done in Chemi black so all fixings match the under bonnet air diverter now. Link to comment Share on other sites More sharing options...
Andrew K Posted March 24, 2017 Author Share Posted March 24, 2017 Also got my cam covers back from the bead blasters and are now masked up and ready for painting which a good friend of mine will be doing at his body shop Link to comment Share on other sites More sharing options...
Kev.O Posted March 24, 2017 Share Posted March 24, 2017 Great scoop Andrew. Do you mend if I ask where you got the screw clips from as I'd like to get some for mine. Link to comment Share on other sites More sharing options...
Andrew K Posted March 24, 2017 Author Share Posted March 24, 2017 Great scoop Andrew. Do you mend if I ask where you got the screw clips from as I'd like to get some for mine. Thanks I got the plastic screw clips off eBay but my girlfriend purchased them for me, when I see her tomorrow I will get her to look through her purchase history so I can post the correct link for you. Link to comment Share on other sites More sharing options...
Kev.O Posted March 24, 2017 Share Posted March 24, 2017 Appreciate it thank you. Link to comment Share on other sites More sharing options...
Andrew K Posted March 25, 2017 Author Share Posted March 25, 2017 Great scoop Andrew. Do you mend if I ask where you got the screw clips from as I'd like to get some for mine. Here you go mate, link to the seller on eBay for the plastic screw clips I bought. http://m.ebay.co.uk/itm/290751035969?_mwBanner=1 Link to comment Share on other sites More sharing options...
Kev.O Posted March 26, 2017 Share Posted March 26, 2017 Thank you Andrew, will order some now. Link to comment Share on other sites More sharing options...
Andrew K Posted April 7, 2017 Author Share Posted April 7, 2017 Had a message from my mate today telling me my cam covers have finally been painted So tomorrow once I've picked them up I can make a start on putting the engine back together and I can start using the supra again. Link to comment Share on other sites More sharing options...
Andrew K Posted April 9, 2017 Author Share Posted April 9, 2017 Picked my cam covers up on Saturday and made a start fitting the baffles back in so everything was ready to fit back on the engine. Link to comment Share on other sites More sharing options...
Andrew K Posted April 9, 2017 Author Share Posted April 9, 2017 Few pictures of everything assembled and back together just needs a dam good clean now ready for japfest in a few weeks time. Link to comment Share on other sites More sharing options...
Kev.O Posted April 11, 2017 Share Posted April 11, 2017 That looks great Andrew. Link to comment Share on other sites More sharing options...
Supraleeturbo Posted April 11, 2017 Share Posted April 11, 2017 Looks the bees knees mate Link to comment Share on other sites More sharing options...
Luxluc Posted April 12, 2017 Share Posted April 12, 2017 Perfect Andrew. Link to comment Share on other sites More sharing options...
ShawnPreece Posted April 12, 2017 Share Posted April 12, 2017 Looking beautiful mate Link to comment Share on other sites More sharing options...
Andrew K Posted April 12, 2017 Author Share Posted April 12, 2017 That looks great Andrew. Looks the bees knees mate Perfect Andrew. Looking beautiful mate Thanks for the nice comments guys I noticed though when fitting the cam covers back on there's a fair few nuts & bolts that are quite rusty looking now so need to sort that out. Link to comment Share on other sites More sharing options...
Andrew K Posted August 5, 2017 Author Share Posted August 5, 2017 Last weekend the 30th i went to the Simply Japanese car show at Beaulieu House, was the first time i have ever been to this show and it was really good and unlike the weather when i left home (raining!) it was nice and sunny there Also was good getting to finally meet and have a good chat with some other members and to put some faces to forum names. Got a few pictures of the MKIV Supra stand and also managed to get some nice shots of my car alone Link to comment Share on other sites More sharing options...
Andrew K Posted August 5, 2017 Author Share Posted August 5, 2017 Link to comment Share on other sites More sharing options...
a98pmalcolm Posted August 5, 2017 Share Posted August 5, 2017 Nice pics Link to comment Share on other sites More sharing options...
Andrew K Posted August 26, 2017 Author Share Posted August 26, 2017 Last weekend i went to the Japanese performance car show at Stoneleigh park. Think this is only the second time this show has been held here but it was a first for me and i had an absolutely awesome day and the weather was perfect, got to catch up with a few fellow members and say Hi to some others i`ve not met before and as you do i got a few pictures of my car on the club stand. Link to comment Share on other sites More sharing options...
