Andrew K Posted July 18, 2013 Author Share Posted July 18, 2013 This keeps getting better and better !! Keep it up mate Thanks it`s not the quickest build ever but i`m doing my best Good work mate! Thanks Link to comment Share on other sites More sharing options...
Andrew K Posted August 12, 2013 Author Share Posted August 12, 2013 Done a bit more work on my engine over the last few weeks got myself some exhaust wrap and got my down pipe wrapped. Also got a K&N breather filter to go on the idle valve,when i tried mounting the filter straight onto the idle valve it was hitting the intake chamber! so had to make up a little extension pipe out of left over bits to move the filter back a bit. Link to comment Share on other sites More sharing options...
Andrew K Posted August 12, 2013 Author Share Posted August 12, 2013 (edited) Final the bit i've been waiting to do got the manifold and turbo on for a test fit, i had to make some more mounting brackets for the turbo heat shield as the originals had rusted to much and was to weak to use! Been getting new oil feed pipping made up as well to replace the old rusty / dirty ones and put new thermal sleeve on them. needed somewhere neat to mount the solenoid so made an alloy mounting bracket for it which fits on the side of the water pump. after doing that and it turned out quite well i wanted to extend this bracket up the side of the manifold so it would act as a heat shield for the top water neck elbow, my plan is to fit the Defi water temp sensor into the elbow where the threaded part is and wanted a bit of protection for it from the manifold. Edited October 17, 2013 by Andrew K (see edit history) Link to comment Share on other sites More sharing options...
Andrew K Posted August 12, 2013 Author Share Posted August 12, 2013 Slowly getting there and i`m happy with the way things are turning out i put the top braided water neck on (this came from Jamie p, Black Beast) with its massive -24 AN fittings Link to comment Share on other sites More sharing options...
Clausz Posted August 13, 2013 Share Posted August 13, 2013 Looks fantastic:P Link to comment Share on other sites More sharing options...
Andrew K Posted August 13, 2013 Author Share Posted August 13, 2013 This has arrived a Whifbitz Billet Cambelt Tensioner Bracket, just wanted to play it safe and did not want anything going wrong! so this is another little job to do and change it over from the stock one. Link to comment Share on other sites More sharing options...
DannoSupra Posted August 13, 2013 Share Posted August 13, 2013 Looking good bud Link to comment Share on other sites More sharing options...
thetrashcanman Posted August 13, 2013 Share Posted August 13, 2013 Looks awesome mate, keep up the good work Link to comment Share on other sites More sharing options...
Andrew K Posted August 13, 2013 Author Share Posted August 13, 2013 Looking good bud Looks awesome mate, keep up the good work Thanks guys Link to comment Share on other sites More sharing options...
wewsupra Posted August 14, 2013 Share Posted August 14, 2013 looking good mate Link to comment Share on other sites More sharing options...
Andrew K Posted September 23, 2013 Author Share Posted September 23, 2013 (edited) while i've come to bit of a stand still regarding my engine as need to order some more thermal sleeve and decide what clutch i want to go with! i thought i`d make a start on my AP Racing brake kit i've got. As you can see from the pictures the disc`s them selves are not in the best condition so purchased myself some new disc`s and mounting bolts for the hub. The fun part was trying to undo all the rusty bolts holding the hub to the disc, i finally managed it but some of them sheared off which resulted in me taking the skin off the knuckles on three of my fingers:Pling: These Front calipers are absolutely massive all i want and need to do with these are give them a good clean down and freshen them up with a new coat of paint. Edited October 17, 2013 by Andrew K (see edit history) Link to comment Share on other sites More sharing options...
Andrew K Posted September 23, 2013 Author Share Posted September 23, 2013 The new disc`s and mounting bolts turned up plus some new pads, once i find a star shaped socket that matches the mounting bolts i can then start putting them back together still need to freshen the calipers up yet but will update with pictures when i have. Link to comment Share on other sites More sharing options...
Carbon_Bullet Posted September 23, 2013 Share Posted September 23, 2013 I see you have the turbo kit bolted on, engine looks clean & fresh, and those brakes will certainly bring you too a stop Link to comment Share on other sites More sharing options...
Andrew K Posted September 23, 2013 Author Share Posted September 23, 2013 (edited) I see you have the turbo kit bolted on, engine looks clean & fresh, and those brakes will certainly bring you too a stop Yeah its getting there slowly cheers, I've been following your build thread closely and got to say its looking impressive to. Edited October 17, 2013 by Andrew K (see edit history) Link to comment Share on other sites More sharing options...
Luxluc Posted September 24, 2013 Share Posted September 24, 2013 Nice Andrew. Those AP's look ace. Cheers Link to comment Share on other sites More sharing options...
Andrew K Posted October 13, 2013 Author Share Posted October 13, 2013 Not much of an update but got my new AP Disc`s mounted to the old cleaned up hub`s using the correct nut & bolt set from AP. Link to comment Share on other sites More sharing options...
thetrashcanman Posted October 13, 2013 Share Posted October 13, 2013 Thank god the calipers weren't shot on those AP's they are much more expensive to replace also you've probably said it, but what turbo/turbo kit is that mate? Link to comment Share on other sites More sharing options...
Slutters Posted October 13, 2013 Share Posted October 13, 2013 Lovely brake setup there mate, next on my list! Link to comment Share on other sites More sharing options...
Parry_10 Posted October 13, 2013 Share Posted October 13, 2013 Saw this build earlier this week. A lot of nice parts and thought going into it, going to be a great supra when its done. Link to comment Share on other sites More sharing options...
Fizzy T Posted October 13, 2013 Share Posted October 13, 2013 Looking good, Got to love AP brakes. Link to comment Share on other sites More sharing options...
Andrew K Posted October 13, 2013 Author Share Posted October 13, 2013 Thank god the calipers weren't shot on those AP's they are much more expensive to replace also you've probably said it, but what turbo/turbo kit is that mate? Your right there about the callipers! But they were working fine before I took them off the car I was braking so are ok The turbo kit is a :- Precision T6765 .68 (67mm Turbo with .68ar) Whifbitz Tubular Manifold Whifbitz 3" Mid / Down pipe 50mm Turbo smart Waistgate 4" Polished Intake pipe 4" K&N filter Link to comment Share on other sites More sharing options...
Andrew K Posted October 13, 2013 Author Share Posted October 13, 2013 Lovely brake setup there mate, next on my list! Looking good, Got to love AP brakes. Thanks for the nice comments guys Link to comment Share on other sites More sharing options...
Andrew K Posted October 13, 2013 Author Share Posted October 13, 2013 Saw this build earlier this week. A lot of nice parts and thought going into it, going to be a great supra when its done. Thanks mate was good meeting you the other night, I'm sure your project will be out there with some of the best as your pretty good with your attention to detail. Link to comment Share on other sites More sharing options...
thetrashcanman Posted October 13, 2013 Share Posted October 13, 2013 Your right there about the callipers! But they were working fine before I took them off the car I was braking so are ok The turbo kit is a :- Precision T6765 .68 (67mm Turbo with .68ar) Whifbitz Tubular Manifold Whifbitz 3" Mid / Down pipe 50mm Turbo smart Waistgate 4" Polished Intake pipe 4" K&N filter Thanks dude thinking of something similar myself, where did you get the kit from? Whiftbitz? Link to comment Share on other sites More sharing options...
Andrew K Posted October 14, 2013 Author Share Posted October 14, 2013 Thanks dude thinking of something similar myself, where did you get the kit from? Whiftbitz? I picked it up as a package deal in the for sale section. Link to comment Share on other sites More sharing options...
