Andrew`s Single turbo 6 speed V161 Build
Andrew K
Been putting this off for a long time now but thought id finally start a thread on what i`m doing. :) and also keep a documentation of everything that gets done on the supra.
Here is a thread I started a while ago now showing what I had done regarding the spoiler, Bonnet, front active Spoiler and stereo install. http://www.mkivsupra.net/vbb/showthread.php?229512-Bits-ive-done-on-my-supra
This is where i am now and i don`t want to go over the top or to mad with my build at the moment! :innocent: i have been gathering and collecting bits for some while now and still have a huge list of bits to get! getting there slowly though. Over the last year and a bit i`ve been working on a TT bottom end & head that i purchased from Jamesy`s supra when he was breaking it, thought this would be a good starting base as Jamesy's engine had been previously built by SRD and only covered roughly 1800 miles since. I also got myself a doner car which i`ve been taking parts of that i need and getting them all cleaned up and selling what i don`t need. I`m also going to be swapping out the auto box for a 6spd V161 conversion which i purchased from keron at extreme performance and this is all ready and waiting to go in the car now, the box had done 59651 miles and was taken from a 97 model supra which had minimal damage and started & drove well also.
Added a picture of the supra that will be getting all these goodies fitted one day! :eyebrows:
The car is an N/A Auto at the moment so gonna be a challenge!
This is my list of parts i have & i`ve done so far and will update as i go on,
I`ll keep you all updated and start adding some pictures of my progress so far. :)
When it comes to fitting it all to the car Lee & the team at SRD will be doing all that side of things so
Looking forward to when that starts. :D
Engine spec so far :-
ARP Head studs
ARP Rod Bolts
ARP Main Bolts
ACL ROD Bearings
ACL Main Bearings
ACL Thrust Washers
New Uprated Rings
OEM Rods and Pistons
Fully Balanced and Line Honed block
SRD Stage 2 Head - Ported and Polished
HKS Cam pulleys
SRD Stage 2 Cams 269 Profile, 9.6mm Lift
Brian Crower Uprated springs
Titanium Retainers
Welded crank timing sprocket
Gates Racing Uprated blue cambelt
New Toyota cambelt tensioner
New Toyota cambelt tensioner pulley (also using a Whifbitz Billet Cambelt Bracket)
TRD thermostat
SRD polished top water neck with custom -24 AN fitting
N/A lower water neck (Helps with clearance because of Turbo)
-24 AN Top braided water neck
SRD custom cam cover Breather kit with -12 AN fittings
-12 AN Cam cover mods
Pre-facelift engine mounts
TRD Engine Mounts
TRD Oil filler cap
TTC Performance oil dipstick
SRD Aluminium Undertray
Lexan spark plug cover
Front upper and lower engine covers painted silver
Metallic sump plug
New OEM Oil filter
New Toyota oil pump
New OEM water pump
New OEM starter motor
New Genuine Toyota crank pulley
New coil pack clips
New OEM throttle cable for manual turbo supra
Turbocharger & Induction :-
Precision T6765 .68 (67mm Turbo with .68ar)
Whifbitz Tubular Manifold
Whifbitz 3" Mid / Down pipe
50mm Turbo smart wastegate
HKS Dump Valve
4" Polished Intake pipe
4" K&N Filter
Exhaust System :-
3" HKS Silent Hi-power
Drivetrain :-
V161 6 speed getrag conversion
Stock dual mass flywheel
Spec stage 1 clutch
Large casing LSD from a 6speed manual (B03B)
New Toyota Prop Shaft
Whifbitz Solid shifter mounts
TRD Gearbox mount
Cooling :-
Chris Wilson SMIC
New OEM Toyota air diverter
Garage Whifbitz SMIC hard pipe kit
Mocal Engine oil cooler kit with Thermostatic oil sandwich plate
Fluidyne Alloy radiator with custom -24 AN fitting
ARP carbon rad plate
Fuel, Tuning & Ecu :-
Syvecs S6 ECU
Fuel rail adaptor
SARD 800cc Drop in injectors
Aeromotive FPR
New Toyota fuel filter
Walbro 485 fuel pump
Suspension, Wheels, Tires & Brakes :-
Tein coilovers
Cusco strut brace
TT Front Anti roll bar
AP Racing big front brake kit
356mm discs on the front
Toyota UK Spec Supra rear brake calipers
320mm discs on the rear
Blitz techno speed Z1's 9x18 front & 10x18 rear
Goodyear eagle F1 tyres all round
Interior & Ice :-
Alpine CDA - 9854R stereo
Alpine KCA - 420i interface adaptor for ipod
Front speakers - JL Audio C2 - 650 Evolution 2 - way components
Rear speakers - JL Audio Evolution TR 650 - CXi
Caliber CA660 Competition series II 6 channel amplifier
lockys96 custom sub-box with a JL Audio 10" sub-woofer driver
konig K5000 seats (Black & Silver)
Toyota supra fitment sub frames
Re-trimmed Oem steering wheel
New Oem 6 speed leather gear knob
New Oem leather hand brake
Original Black carpet
Black Head lining, Sun visors & interior light fitting
Dash panels painted silver to match the silver on the seats
Top Secret gauge pod
Custom made 2 gauge pillar pod
Defi control unit2
60mm defi boost gauge
60mm defi oil pressure
60mm defi water temp
60mm defi fuel pressure
60mm defi EGT
AEM AFR Gauge
Exterior :-
TRD spoiler
Original UK Spec bonnet & air scoop
Custom made under bonnet air diverter for the air scoop
Full OEM front active spoiler with manual override device fitted
S2000 stubby conversion aerial kit
Zunsport front grill set
Facelift headlights
Facelift front indicators
Clear side indicators
OEM Front small mud flaps
Edited by Andrew K (see edit history)
Nice spec list! :) What sort of power you aiming for?
The only thing I would change is maybe the injectors, Becuase if your going for a big single with big power your going to want 1000cc injectors to feed enough fuel :D
800 should be enough for 700bhp or thereabouts, possibly more. Overspeccing injectors is pretty common these days, it hurts idle/offboost driving IMO
only looking to be around the 600 mark really, well i hope anyway :)
Once i had got myself an engine stand + engine i had purchased :) i got the stand all assembled and engine mounted up in my garage and started giving the block a coat of very high temperature engine enamel paint, also fitted my new water pump. this is an old pic as im changing the top water elbow so it can take the -24 AN fitting.
Excuse all the rubbish that`s in the back ground!
  • 2 weeks later...
Got my new manual gear surround painted up so it matches the rest of my dash, i didnt get any pictures while i was getting it prepped for painting :( but it was just sanded down to get the rubber texture off and then sanded with wet & dry paper to give it a nice key for the paint, then carefully masked up before painting. Also got myself a new OEM 6 speed gear knob to finish it all of when its installed.
