billy0090 Posted May 31, 2013 Share Posted May 31, 2013 afternoon, I read somewhere you can pull a fuse when the spoiler is down to make it stay down. does any one know where this is located? cheers Quote Link to comment Share on other sites More sharing options...
ellis Posted May 31, 2013 Share Posted May 31, 2013 Either that or get one of AndrewOW's natty spoiler override switches - allows you to put it up and down at will - better for speed bumps and tramps in the road. Quote Link to comment Share on other sites More sharing options...
fastcar Posted May 31, 2013 Share Posted May 31, 2013 Isn't there a button in the car below the sterio that allows you to keep it in the down position Quote Link to comment Share on other sites More sharing options...
billy0090 Posted May 31, 2013 Author Share Posted May 31, 2013 no, you can put it down with the ignition on but as soon as you start the car it goes back up and only comes down around 60mpH i believe. I have pmed a guy on there that i found when i searched active spoiler that makes the switch . Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted May 31, 2013 Share Posted May 31, 2013 the fuse is next to the throttle pedal. Put the spoiler down when the ignition is on then pull the fuse. It will stay down but it finds kerbs hella fast. Quote Link to comment Share on other sites More sharing options...
fastcar Posted May 31, 2013 Share Posted May 31, 2013 no, you can put it down with the ignition on but as soon as you start the car it goes back up and only comes down around 60mpH i believe. I have pmed a guy on there that i found when i searched active spoiler that makes the switch . Really? I will have to check this I'm sure when I push the manual button it just stays down intill I tell it over wise. But then I haven't ever really tryed it to be honest. Quote Link to comment Share on other sites More sharing options...
jonc Posted June 1, 2013 Share Posted June 1, 2013 (edited) Really? I will have to check this I'm sure when I push the manual button it just stays down intill I tell it over wise. But then I haven't ever really tryed it to be honest. If its original OEM fittings then as soon as you start the car the spoiler will retract. It will lower again at 100 KPH I think (about 60ish MPH if your converter is fitted correctly). The are a couple of controllers that have been made by different members (i Think Garfy may have made one years ago) which allows you to control the blade your self. If I remember rightly removing the fuse will keep the blade down but I think the light on the switch flashes continuously (I could be wrong on that one though:blink:). The actual blade is quite low when down so speed bumps etc will cause a few problems Edited June 1, 2013 by jonc (see edit history) Quote Link to comment Share on other sites More sharing options...
Gpro Posted June 1, 2013 Share Posted June 1, 2013 you could cut any wires leading to the active spoiler Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted June 1, 2013 Share Posted June 1, 2013 You could unplug the connector located under the O/S headlight. Not sure if it will throw up any warnings but worth a try? Three 10mm bolts to undo the head light and the connector sits underneath it. It's grey, you'll spot it straight away. Quote Link to comment Share on other sites More sharing options...
Alex Posted June 2, 2013 Share Posted June 2, 2013 To get no errors you drop it then pull the plug out of the control unit behind the stereo. Top silver box. Unplugging this stops the car knowing its even there. Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted June 2, 2013 Share Posted June 2, 2013 Buy one of the override switches mate, you want to have the flexibility with speed bumps! Looks very oem when fitted too. AndrewOW is your man, he has taken over Garfys legacy Quote Link to comment Share on other sites More sharing options...
SteveC Posted June 2, 2013 Share Posted June 2, 2013 If Toyota had originally designed the front spoiler with a switch on the dash to only manually lower/raise it as required, I wonder if people would now ask : "Is there a way to make it lower automatically when you get to around 60mph?" Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted June 2, 2013 Share Posted June 2, 2013 Either that or get one of AndrewOW's natty spoiler override switches - allows you to put it up and down at will - better for speed bumps and tramps in the road. Buy one of the override switches mate, you want to have the flexibility with speed bumps! Looks very oem when fitted too. AndrewOW is your man, he has taken over Garfys legacy Thank you chaps. Yes, that's me. They are a simple ECU that just bypasses the factory fitted ECU without damaging anything. I've replied to your PM. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted June 2, 2013 Share Posted June 2, 2013 Thank you chaps. Yes, that's me. They are a simple ECU that just bypasses the factory fitted ECU without damaging anything. I've replied to your PM. I have one of AndrewOW's little ECU's very easy to fit and well made. Recommended. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted June 16, 2013 Share Posted June 16, 2013 Well, I thought I would provide a quick snap of the override module to show what it looks like, and hope it doesn't look too complicated to install. I provide full installation instructions too. Quote Link to comment Share on other sites More sharing options...
Andrew K Posted June 16, 2013 Share Posted June 16, 2013 If the car hasn't got any of the loom fitted from the factory, can these be made to work with the factory switch and all wiring to reach to the plug on the motor for the spoiler? Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted June 16, 2013 Share Posted June 16, 2013 Yes, indeed. I can also produce an override module that contains the complete loom direct to the front spoiler. Quote Link to comment Share on other sites More sharing options...
Havard Posted June 16, 2013 Share Posted June 16, 2013 Either that or get one of AndrewOW's natty spoiler override switches - allows you to put it up and down at will - better for speed bumps and tramps in the road. I have one of these and they are the shizz. I don't know how members get on with the spoiler being permanently down as we have scraped ours a couple of times when we have forgotten to put it back up. These come with simple instructions on how to fit the controller too. H. Quote Link to comment Share on other sites More sharing options...
kitch79 Posted August 3, 2013 Share Posted August 3, 2013 Thank you chaps. Yes, that's me. They are a simple ECU that just bypasses the factory fitted ECU without damaging anything. I've replied to your PM. Darn, wish I had seen this thread earlier ha! Ive just spent hours on the drive fitting my ECU, buttons, and spoiler! Yup, worked a treat with engine not running, thought "jackpot" cleaned it up, removed my grubby fingers prints off everything... AND yep, started car, spoiler came up Didnt realise I couldnt choose to have it down at slow speeds!! came down at around 60 as u say. with an override switch, will it still use OEM buttons? and would it still be auto or is it now just totally manual? Cheers, danny Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted August 5, 2013 Share Posted August 5, 2013 With an override module, you'll be able to manually control the spoiler completely from when you turn the ignition on. Quote Link to comment Share on other sites More sharing options...
Guest 111tom Posted October 30, 2015 Share Posted October 30, 2015 Hey man, Do you still make the bypass switch? Quote Link to comment Share on other sites More sharing options...
