Refurb Headlights
darrenlee1981
Just do it mate its not that hard once you take the plunge
The hardest bit is actually putting it the oven and then attacking it with a screwdriver :eyebrows:
I have to admit to having gone wildly over budget on this tho,
I've had to buy a second tube of Asda smart price toothpaste!
I did do a scrub on the outside to start with but then it became obvious that i'd have to split em and do the inside as well.
Cheers Matt
Cheers Matt
Matt, what's the procedure? take lights off car, whack in oven, take apart, polish with toothpaste inside and out?
How do you reseal to stop rainwater getting in after?
:yeahthat:
To be honest I haven't put it back together again yet :)
but that is the plan this weekend, having put it in the oven once I've now got a feel for how long to get it to the right consistency.
honestly if I can do it to get my 20yr old sup one step further away from chavdom anyone can,
any q's you got do a search or put in here and me or someone will answer I'm sure.
I got lots of info just browsing around and also here was useful for the actual splitting, http://mkiv.com/techarticles/headlights/index.html
Other materials can be used but bang per buck, hand polishing with 25p a tube toothpaste takes some beating.
hth,
Matt
Quick run-down of the process:
Heat lights in oven
Split lights (clips & sealant)
Clean up inside / outside of lens
Paint inner if wanting to "facelift look" the insides
Heat up both parts of light (lens & housing)
Push back together fully
Back in oven for sealants to merge back together
Clips on
Unfortunatly with any splitting of headlights on any car, there is a element of risk that a tiny gap is left in the sealant & moisture can get in, but usually if fine if they havent been split too many times.
Hmm I should apply to start offering this as a service with the amount of times ive gone through this process myself & ran through for others >
  • 2 weeks later...
