scotty_1987 Posted May 31, 2013 Share Posted May 31, 2013 Hello. Having alot of trouble getting my bottom pulley off. I dont really have the means of making a tool up at the moment. Does anyone have a tool that i could buy/borrow/rent please very nicely. Im located near cambridge if anyone lives in the area. Thanks Scott Quote Link to comment Share on other sites More sharing options...
Josh42 Posted May 31, 2013 Share Posted May 31, 2013 Just drop the car in 4th gear and using a very long bar and a hefty ratchet/torque wrench, crack it. Quote Link to comment Share on other sites More sharing options...
st3ven1 Posted May 31, 2013 Share Posted May 31, 2013 Have you tried locking a breaker bar against the chassis leg and cranking the engine over to crack the nut?(obviously don't start the engine) Alternatively there is an inspection hole in the auto box which faces towards the front of the car underneath, there is a black rubber grommet (about 4" x 6") which can be removed which would then allow you to lock the crank using a breaker bar or similar. This is how I done it on my TT auto. Quote Link to comment Share on other sites More sharing options...
scotty_1987 Posted May 31, 2013 Author Share Posted May 31, 2013 Should of said it was auto lol. I have tried cracking it off by turning the engine over but no luck. I didnt realise there was an inspection hole. Ill go have a look and see how i get on. Thanks Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 31, 2013 Share Posted May 31, 2013 keep at it with the engine mate takes a couple of goes make sure your battery is good also Quote Link to comment Share on other sites More sharing options...
reeceu Posted May 31, 2013 Share Posted May 31, 2013 i have just got over a similar issue, best way is to lock the engine up as i used a charged battery my starter wouldnt budge it! if this all fails i got a friend to lock the flywheel through the starter motor hole and then got on a big breaker bar with a 4 foot jack handle and that cracked it! good luck Quote Link to comment Share on other sites More sharing options...
listy Posted May 31, 2013 Share Posted May 31, 2013 +1 for bracing a breaker bar, but I did it on the floor (passenger side). A few crank overs and it cracke off Quote Link to comment Share on other sites More sharing options...
scotty_1987 Posted May 31, 2013 Author Share Posted May 31, 2013 Managed to get it off using the inspection hole And a pry bar. Thanks for the help :-) Quote Link to comment Share on other sites More sharing options...
