T14PPA Posted May 30, 2013 Share Posted May 30, 2013 Ive given up on this gizzmo boost controller i have. Its too confusing. I just want a good but simple to use boost controller. What do you recomend? Quote Link to comment Share on other sites More sharing options...
mattdavies Posted May 30, 2013 Share Posted May 30, 2013 Greddy Profec B (not spec 2) Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 30, 2013 Author Share Posted May 30, 2013 Greddy Profec B (not spec 2) Why do you say that? Whats wrong with spec 2? As someone is selling that one Quote Link to comment Share on other sites More sharing options...
mattdavies Posted May 30, 2013 Share Posted May 30, 2013 I have an Original Profec B and it is simple, has High / Low / Sharpness knobs and that's it so you basically twist the knob till your at the boost you want, the sharpness adjust the speed it open and closes the waste gate so you can get a constant boost pressure. The knobs are flush in the unit till pressed then they pop out and pressed to put them back in. There are two buttons that are the power and the high / low boost selection Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 30, 2013 Author Share Posted May 30, 2013 I have an Original Profec B and it is simple, has High / Low / Sharpness knobs and that's it so you basically twist the knob till your at the boost you want, the sharpness adjust the speed it open and closes the waste gate so you can get a constant boost pressure. The knobs are flush in the unit till pressed then they pop out and pressed to put them back in. There are two buttons that are the power and the high / low boost selection Fair enough. Sounds as simple as possible. Thats what i want really. Quote Link to comment Share on other sites More sharing options...
mattdavies Posted May 30, 2013 Share Posted May 30, 2013 That's why I got it. There maybe other options, someone may be along in a bit to give you them but from my search when I was looking this seemed simple enough for me and from a reputable company Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 30, 2013 Author Share Posted May 30, 2013 That's why I got it. There maybe other options, someone may be along in a bit to give you them but from my search when I was looking this seemed simple enough for me and from a reputable company Does it have a gain setting though? Quote Link to comment Share on other sites More sharing options...
Gpro Posted May 30, 2013 Share Posted May 30, 2013 blitz Dual SBC boost controller works good for me! 4 different boost settings which one touch of a button you can switch from 1,2,3,4 also max boost limit. If it exceeds your prefered max boost it will knock the boost down Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 30, 2013 Author Share Posted May 30, 2013 We talk when i see you george. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 30, 2013 Share Posted May 30, 2013 A simple and effective solution would be a 'spring and ball' type manual boost controller. If you want an EBC then I'd go with either Blitz or HKS. Quote Link to comment Share on other sites More sharing options...
