mark newman Posted May 30, 2013 Share Posted May 30, 2013 do you need a resistor pack , when fitting low impedance injectors , I can not remember and I need new ones Link to comment Share on other sites More sharing options...
Nic Posted May 30, 2013 Share Posted May 30, 2013 Yup Link to comment Share on other sites More sharing options...
heckler Posted May 30, 2013 Share Posted May 30, 2013 depends on the ecu Link to comment Share on other sites More sharing options...
mark newman Posted May 30, 2013 Author Share Posted May 30, 2013 I have a Syvecs s6 Link to comment Share on other sites More sharing options...
heckler Posted May 30, 2013 Share Posted May 30, 2013 Pretty sure some ECU should be able to handle both - may be worth checking with Ryan if the S6 can Link to comment Share on other sites More sharing options...
mark newman Posted May 30, 2013 Author Share Posted May 30, 2013 bump Link to comment Share on other sites More sharing options...
heckler Posted May 30, 2013 Share Posted May 30, 2013 Right, taken from the syvecs forum, as stated by ryan "The S6 will only run high impendance injectors directly, so a resistor pack is needed for low impendance injectors" Link to comment Share on other sites More sharing options...
Kaan W Posted May 30, 2013 Share Posted May 30, 2013 And heres the link - http://www.syvecs.com/forum/viewtopic.php?f=6&t=6 Right, taken from the syvecs forum, as stated by ryan "The S6 will only run high impendance injectors directly, so a resistor pack is needed for low impendance injectors" Beat me to it! Link to comment Share on other sites More sharing options...
mark newman Posted May 30, 2013 Author Share Posted May 30, 2013 thanks for that . Link to comment Share on other sites More sharing options...
Lee P Posted May 30, 2013 Share Posted May 30, 2013 Run high impedance if you can the control is much better You need a set of asnu injectors in that car Link to comment Share on other sites More sharing options...
Wez Posted May 30, 2013 Share Posted May 30, 2013 Run high impedance if you can the control is much better You need a set of asnu injectors in that car Link to comment Share on other sites More sharing options...
mark newman Posted May 30, 2013 Author Share Posted May 30, 2013 Will they be ok with race fuel , and what price can you do set of 1600cc . was thinking of low impedance as they are half price as I would want to change the injectors often as running race fuel, not that good for any matrial, as i just found out today. Link to comment Share on other sites More sharing options...
Lee P Posted May 30, 2013 Share Posted May 30, 2013 Will find out about the race fuel Won't need 1600cc with the asnu's Link to comment Share on other sites More sharing options...
mark newman Posted May 30, 2013 Author Share Posted May 30, 2013 why not will I need bigger then Link to comment Share on other sites More sharing options...
mark newman Posted May 31, 2013 Author Share Posted May 31, 2013 What would happen if you run low impedance injectors on a s6 without a resistor pack, could it be mapped or would the s6 say no, with all its safty in place. Link to comment Share on other sites More sharing options...
