Expansion tank
mull1986
I've changed the rad cap and after two, 7 mile runs the levels seem to be ok but will keep an eye on it as I've just done the head gasket on it a month ago and this issue with the expansion tank was the first of many symptoms of a blown head gasket and I was worried that my engine was knackered!!!
Best £30 I spent on this forum!!
Thanks everyone
Think I might have to do that cos I went on a 90 mile round trip and after the tank was empty and rad levels are down, even tho I put a new water pump and thermostat on about 8 months ago. Maybe time for a new rad but that got done 4 yrs ago by the previous owner
Carbon monoxide in the coolant sniffer test, coolant system pressure test, remove and examine water pump, remove and change thermostat, remove and flow test rad, physically examine rad. In no particular oredr...
How do I check the coolant pressure, sorry if its a logical explanation
Hope its cured for you and glad to help, i always start with the cheap fix first, the mkiv engines
aren't known for doing head gaskets.
Mine had gone cos when I took the head off I had water sitting where the pistons are and quite a lot of it, just unlucky I suppose :/
Cheers kaan, I filled it the full line then went driving and the tank was empty when hot and cold later still?
Engine cold _ Fill rad to very top. Fill overflow bottle to line on the front of the tank "Full Level". Overflow bottle level should return to full level after use, and after the engine is stone cold again. Coolant system pressure holding test is done with special pump, by a garage. Checks whole system bar the rad cap holds pressure. Rad cap best just renewed with genuine Toyota one. DO NOT fit a higher pressure cap, they are for very special needs and NOT what you want.
Thanks, I have fitted a new one but not a Toyota one so will try that now.
Don't just buy bits at random, if even a none genuine cap made no difference it's unlikely a genuine one will fix it. Sounds like it has a coolant leak, sometimes the hot water evaporates before a drip is found. Water pump bearing drain tube leaking? You need to take it to a garage and have a pressure test done!!
