3rd actuator??
matthewswinimer
hi guys iam currently in the process of removeing all the sequential stuff cause iam in permanant ttc and iam fabbing up dual intakes....anyways i have everything figured out except for this 3rd actuator that looks like a waste gate in the number 2 turbo....i was under the assumption that we only had 1 wastegate? it looks like this one opens up a flapper that connects the 1 and 2 turbos exhaust ports.kinda like a bypass? correct me if iam wrong but could this be somthing that gives number 2 turbo a little bit of exhaust flow before opening up the large flapper on the #2 turbo when in sequential mode. kinda like a prespool? anyways iam wondering if this should stay shut or be wired open when in ttc?
on a side note if all this is true with only 1 wastegate wouldnt the #2 turbo just spin wide open and the #1 turbo regulate the boost.....?
thanks in advance
