Gretie22 Posted May 27, 2013 Share Posted May 27, 2013 Hello, right I have searched this but can't seem to find a straight answer. I need a new battery, my car is a 93 j spec auto tt, which battery do I need as was going to order one online. Thanks. Quote Link to comment Share on other sites More sharing options...
ellis Posted May 27, 2013 Share Posted May 27, 2013 Halfords HCB005 - easy job! Quote Link to comment Share on other sites More sharing options...
Gretie22 Posted May 27, 2013 Author Share Posted May 27, 2013 Awesome thanks for that. Quote Link to comment Share on other sites More sharing options...
Wez Posted May 27, 2013 Share Posted May 27, 2013 I got a direct replacement Yuasa battery from All Parts, the Halfords battery required terminal adapters on a jspec and was very expensive in comparison Quote Link to comment Share on other sites More sharing options...
Rummy Posted May 27, 2013 Share Posted May 27, 2013 I bought the HB005 two days ago and never needed any adapters for my jspec. Just sayin' Quote Link to comment Share on other sites More sharing options...
Wez Posted May 27, 2013 Share Posted May 27, 2013 I bought the HB005 two days ago and never needed any adapters for my jspec. Just sayin' Maybe yours was already converted Quote Link to comment Share on other sites More sharing options...
snake Posted May 27, 2013 Share Posted May 27, 2013 Try toyota ask for some discount it may work out cheaper than halfords Quote Link to comment Share on other sites More sharing options...
Gretie22 Posted May 27, 2013 Author Share Posted May 27, 2013 I'll have to see if mines been converted, if not which battery will I need? Or how much are the adapters? Quote Link to comment Share on other sites More sharing options...
Wez Posted May 27, 2013 Share Posted May 27, 2013 I'll have to see if mines been converted, if not which battery will I need? Or how much are the adapters? Jspec and UK are both post type terminals, only difference is the UK uses larger / thicker terminals. Quote Link to comment Share on other sites More sharing options...
Rummy Posted May 28, 2013 Share Posted May 28, 2013 (edited) I'll have to see if mines been converted, if not which battery will I need? Or how much are the adapters? Halfrauds HB005 Or if you're loaded HCB005 Whoops, just re-read your post. If its not been converted...pass. Edited May 28, 2013 by Rummy (see edit history) Quote Link to comment Share on other sites More sharing options...
stevie_b Posted May 28, 2013 Share Posted May 28, 2013 (edited) Halfords is the convenient and immediate option. For the more price-conscious, I've always had great service from these guys and their website is easy to use: http://www.performancebatteries.co.uk/ Looks like they list a couple of batteries for the supra, and either one should be fine. I'd go for the Varta: http://www.performancebatteries.co.uk/product/D47/. At £55 it's cheaper than both of the Halfords ones, and has a higher cold-cranking amps rating. Or as someone has said, Toyota dealers can be surprisingly competitive on price. Edited May 28, 2013 by stevie_b (see edit history) Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 28, 2013 Share Posted May 28, 2013 I fitted a HCB005 just fine as well, and there's no sign of the terminals ever being changed... Quote Link to comment Share on other sites More sharing options...
Wez Posted May 28, 2013 Share Posted May 28, 2013 There is also a technical reference for batteries on this site http://www.mkivsupra.net/vbb/showthread.php?30238-The-definitive-battery-thread Quote Link to comment Share on other sites More sharing options...
Gretie22 Posted May 28, 2013 Author Share Posted May 28, 2013 Well it looks like its been converted. I'm in no rush, cars off the road until nov. Brilliant thanks, think i'll order one from these guys, bargain. Quote Link to comment Share on other sites More sharing options...
Wez Posted May 28, 2013 Share Posted May 28, 2013 I fitted a HCB005 just fine as well, and there's no sign of the terminals ever being changed... From memory the HCB005 is the battery listed under the Halfords guide for the MKIV which also refers to the UK model and has large battery terminals, are you able to confirm if it is indeed large terminals? I converted my TT6 to large terminals a long long time ago, with the NA I just picked up a direct replacement Yuasa battery. Quote Link to comment Share on other sites More sharing options...
Scooter Posted May 28, 2013 Share Posted May 28, 2013 Just for clarification I think facelifts had small terminals (many will have been changed by now) the early J-specs had the standard larger ones. Quote Link to comment Share on other sites More sharing options...
Wez Posted May 28, 2013 Share Posted May 28, 2013 Just for clarification I think facelifts had small terminals (many will have been changed by now) the early J-specs had the standard larger ones. Are you sure, my TT6 is a 1996 pre facelift and my NA was a 1994. Quote Link to comment Share on other sites More sharing options...
Guest Rab88 Posted May 28, 2013 Share Posted May 28, 2013 I've never had good experiences with halfords batteries. If you know someone with a costco card and you have a costco near you, they do very good prices on Bosch S5 silver plus batteries. 5 year warranty too. Quote Link to comment Share on other sites More sharing options...
