clutch rattle
Guest berghard55
Guest berghard55
Hi guys, I'm getting a rattling sound from wot it sounds to b from the clutch area, its an uprated clutch but only happens once I've been driving it for a while. When I'm stationary if I engage the clutch pedal it stops! Any ideas wot it cud b?
Is it multi plate or single plate, with stock flywheel or lightened? From what I've heard, all multi plates rattle in neutral with clutch pedal engaged. And my stock clutch and flywheel also make very little noise when hot and stationary without clutch depressed, sound is gone when I engage the clutch also.
edit, got it the wrong way around...
Less "txt spk" please.
