T2 MSW Posted July 3, 2013 Author Share Posted July 3, 2013 Engine is now all buttoned up and ancillaries bolted on. I need a bolt for the power steering pump as 1 was missing when I bought the engine which explains why it was flat up against the tensioner when I picked it up. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted July 4, 2013 Share Posted July 4, 2013 I got bolt if you want to pm me your address. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 6, 2013 Author Share Posted July 6, 2013 Busy day today. Got the engine off the stand and into the garage. Flywheel fitted to the engine and torqued up. Then fitted the gearbox and clutch and bolted eveything up. Engine and gearbox is now ready to be dropped into the car. Also got myself an engine wiring loom so as soon as that arrives I can get the engine wired up. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 14, 2013 Author Share Posted July 14, 2013 Spent some time this weekend pulling all the fuel lines out and replacing them with my -10 feed and -6 return and also fitted my FPR. Started on the fuel tank as well but need to do some research on wiring and how to join the feeds from the twin walbro to the -10 bulk head fitting. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted July 15, 2013 Share Posted July 15, 2013 Mmmm .. nice and clean. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 21, 2013 Author Share Posted July 21, 2013 Busy weekend. Went to oulton park Saturday to watch Time Attack which was a great day out. Then in the evening dropped my engine and gearbox into my shell. Took a while and some messing about to get it to sit on the engine mounts but got there eventually. Then today I have spent time doing the solid shifter bushes and bolting all the gearbox parts up and ensure it works correctly. Need to get some clutch fluid to endure the clutch works. Then ran into two problems. Was going to fit the diff in the car but one of the rubber mounts is completely missing, does anyone know how easy either stock replacements or solid versions are to get into the subframe whilst still on the car - or is it a subframe out job? Second problem was working out all the ground connections on the wiring loom and connectors. Could get earth down to the ECU harness but no power. Only think I could work out was the connector from the fuse box onto the wiring loom (as below) is different from my wiring loom. Eventually after ruling everything else out I got brave and jumped the 12v feed from the fusebox to the same colour wire on the wiring loom - hey presto 12V at the ECU connector. Cut the connectors off and temp wired with a chocolate box and hey presto the ECU fires into Life - all be it with a really old firmware on it Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted July 21, 2013 Share Posted July 21, 2013 Did you get the bolts i sent? Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 21, 2013 Author Share Posted July 21, 2013 Did you get the bolts i sent? No fella Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 21, 2013 Author Share Posted July 21, 2013 Whilst talking about bolts I also need 2 x bolts for the engine mounts to bolt them to chassis. Does anyone have them? Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted July 21, 2013 Share Posted July 21, 2013 No fella Oh! thats not good, i did wonder why i aint heard from you... i best pop to the post office and fire some F**£s into them - - - Updated - - - Whilst talking about bolts I also need 2 x bolts for the engine mounts to bolt them to chassis. Does anyone have them? The nuts you mean? Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 21, 2013 Author Share Posted July 21, 2013 Oh! thats not good, i did wonder why i aint heard from you... i best pop to the post office and fire some F**£s into them - - - Updated - - - The nuts you mean? Thought you had just forgotten about it :)Yeah I mean the nuts. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted July 21, 2013 Share Posted July 21, 2013 Thought you had just forgotten about it :)Yeah I mean the nuts. No mate i posted out in a brown envelope pretty much the next day. I have more but i think we should wait couple of days as they might arrive. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 24, 2013 Author Share Posted July 24, 2013 Tonight's little effort after the manifold and turbo showed up today Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted July 24, 2013 Share Posted July 24, 2013 That looks tasty! Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted July 25, 2013 Share Posted July 25, 2013 Niiiice Quote Link to comment Share on other sites More sharing options...
Luxluc Posted July 25, 2013 Share Posted July 25, 2013 Wow ... very nice. Quote Link to comment Share on other sites More sharing options...
mplavery Posted July 25, 2013 Share Posted July 25, 2013 Looking good buddy Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 30, 2013 Author Share Posted July 30, 2013 Spent a small fortune today, Wheels have been ordered. Also ordered all sensors for syvecs which will be the project for the weekend. Finally FMIC and rad should be ordered tomorrow with the remaining fluids. Hopefully that's everything I need to make some serious progress this weekend. One pain in the arse thing is the front wheels need spraying because Rota dont dont wheels in different sizes in the same colour which seems stupid. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted August 4, 2013 Author Share Posted August 4, 2013 Very difficult day today. I can tell you that taking the rear subframe out on your own, installing diff mounts & reinstalling is very difficult. At least the most difficult job on the car in now done Does anyone know the torque for the rear subframe bolts as its not in the Toyota workshop manuals Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted August 4, 2013 Share Posted August 4, 2013 Very difficult day today. I can tell you that taking the rear subframe out on your own, installing diff mounts & reinstalling is very difficult. At least the most difficult job on the car in now done Does anyone know the torque for the rear subframe bolts as its not in the Toyota workshop manuals Bet that wasn't easy on the floor, not a nice job I bet. Quote Link to comment Share on other sites More sharing options...
C12MMO Posted August 4, 2013 Share Posted August 4, 2013 Re torque figures, if you can see it I took a screenshot of a website months ago. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted August 5, 2013 Author Share Posted August 5, 2013 perfect thanks Quote Link to comment Share on other sites More sharing options...
Guest Rob Day Posted April 25, 2014 Share Posted April 25, 2014 Hi Mike. Long time since we last spoke, so I thought I would pop onto see how's its going, but it appears the project thread has come to a halt, I hope its nothing serious? The Classic Impreza Is in Subaru heaven, and the running gear is in Austria. I've owned another since which was fun, but time for a change maybe? Rob Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted October 7, 2014 Author Share Posted October 7, 2014 About time I got this project finished .... So its time to hand it over to someone who has the time to finish it. Hopefully car is going to Whifbitz next week for some actual progress. A small list I gave Paul earlier of jobs remaining to be done Brakes fiting - plus a spliter making up for the front brake lines as its had an ABS delete. Intake removing and the ICV plate welding - (Supra ICV wont fit). Also Syvecs MAP sensor welding in. Engine mount bolts fitting (I cant find any) Rad rubbers that the rad slots into. FMIC fitting and pipe work making up (intake side) Oil cooler supply & fitting Turbo oil feed and drain fitting new clutch preasure plate supply and fit. Syvecs sensors wiring Dash pod for the Dash2 suply and fitting. Some form of suspention supply and fit Exhaust fit Fuel pump fit and make up the feed and return into the tank. (The lines are already run) New windscreen Quote Link to comment Share on other sites More sharing options...
Havard Posted October 7, 2014 Share Posted October 7, 2014 About time I got this project finished .... So its time to hand it over to someone who has the time to finish it. Hopefully car is going to Whifbitz next week for some actual progress. A small list I gave Paul earlier of jobs remaining to be done Brakes fiting - plus a spliter making up for the front brake lines as its had an ABS delete. Intake removing and the ICV plate welding - (Supra ICV wont fit). Also Syvecs MAP sensor welding in. Engine mount bolts fitting (I cant find any) Rad rubbers that the rad slots into. FMIC fitting and pipe work making up (intake side) Oil cooler supply & fitting Turbo oil feed and drain fitting new clutch preasure plate supply and fit. Syvecs sensors wiring Dash pod for the Dash2 suply and fitting. Some form of suspention supply and fit Exhaust fit Fuel pump fit and make up the feed and return into the tank. (The lines are already run) New windscreen Sounds expensive..!! Quote Link to comment Share on other sites More sharing options...
