Rich.2211 Posted May 25, 2013 Share Posted May 25, 2013 (edited) Just popped into the garage to fit my new water pump to the engine (2JZGE) and comparing it against the water pump I've removed there's one pretty obvious difference - there seems to be an extra connection for a coolant hose? You can see it on the front section of the water pump, about 1.5" long. The only other difference I've noticed after a quick look is one less bolt holding the front of the water pump to the rear housing. The replacement is an ADL Blueprint item if that is of any help. Any ideas what this water pump is from? Also, can I still use this water pump and just blank off the extra part? Edited May 25, 2013 by Rich.2211 (see edit history) Link to comment Share on other sites More sharing options...
Lee P Posted May 25, 2013 Share Posted May 25, 2013 Thats just the oulet when the pump fails, they didnt all have them. Water will come out of that pipe when the water pump is faulty, put a short bit of hose on it and run it down the side of the alternator. Link to comment Share on other sites More sharing options...
Kaan W Posted May 25, 2013 Share Posted May 25, 2013 Incase my new water pump has one, can it just be blocked off as the previous models never had it anyway? Link to comment Share on other sites More sharing options...
Lee P Posted May 25, 2013 Share Posted May 25, 2013 You can do, its just a good indication the water pump is starting to fail Link to comment Share on other sites More sharing options...
Rich.2211 Posted May 25, 2013 Author Share Posted May 25, 2013 Thats just the oulet when the pump fails, they didnt all have them. Water will come out of that pipe when the water pump is faulty, put a short bit of hose on it and run it down the side of the alternator. Huge thanks for that piece of info there! I am about send you a pm regards a few parts. Link to comment Share on other sites More sharing options...
Lee P Posted May 25, 2013 Share Posted May 25, 2013 No problem at all Link to comment Share on other sites More sharing options...
keron Posted May 25, 2013 Share Posted May 25, 2013 Sounds like the new one is for a tt model not a na... If that's the case it will not fit? Iirc the tt only had that part (water pipe) not the na. Link to comment Share on other sites More sharing options...
Kaan W Posted May 25, 2013 Share Posted May 25, 2013 Is the bolt pattern not different on TT pumps? Link to comment Share on other sites More sharing options...
Rich.2211 Posted May 26, 2013 Author Share Posted May 26, 2013 All bolted up and it seems to fit okay Link to comment Share on other sites More sharing options...
