NA-T oil return lines
bluedrag
hey guys guna start my NA-T conversion soon just wondering if the factory 2jzge sump has a plugs on it somewhere that i can hook up as a oil return line for the turbo? to save having to drill and weld the sump?
also if it does can someone post a pic or link me to one please =)
cheers
Nope it doesn't there is a recess where the tt oil return goes too but you have to drill it. Check out my build thread or club nat on this forum there's loads of info on it
I must understand fully before posting....... There is another location you can drill to fit an oil return and means you can do it with the engine in and sump moved out the way
Edited by Fly (see edit history)
