Misfire on a N/A ...:( after engine wash.....
Guest last light bulb
Why don't you do a drop test mate? At least you'll know which cylinder is missing?
Disconnect the clips from each of the leads where they connect to the distributor cap.
Start the car and using an INSULATED pair of pliers and INSULATED gloves and being very careful, drop one lead out of the distributor at a time and replace it after a few seconds.
When you notice that the engine pitch doesn't change, that's your dead cylinder.
It'll be either a dead plug or lead if not water in the well.
uhm was thinking of trying that tomozz..just run outa light tonight...and patience ha......im wondering if if number 5 and number 6 were drowning in water, wether they have broken..and need replacement now......hope i dont need new HT leads......ok thank you josh...will try tomorrow
hope its a plug....60 gbp though for a set :/...if she needs it she needs it...I just changed them not to long ago...I am never cleaning my engine again hahaha ;)
Edited by last light bulb (see edit history)
Oh i see,, mmm...thats what ive been quoted so far form two diffrent motor parts supplyers.....
- - - Updated - - -
it cost me that last time i bought some for her.
i havnt seen many bears back ends..but im sure there rough aha....thanks rich....mmm checked the distributer cap, and it seemed dry in there, no condensation......thank you though...all helps...everything seems dry this is what i cant make out?......maybe running with the two rear plugs doing a jack couste swimming has damaged them?........i shall take mr joshes advice and try to find the dead cylinders tomorrow, i`ll double make sure, i`ll spray all electrical connectors with MR WD40 fish oil.......and then hair dry every connector and HT lead ....we will find this gremiln fellas!!!!
