Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 Hi uhm, well its summer time...and the shows are on, and my supra is misbehaveing ?? after running fine fine ages....(Murpheys law). I did a light tune up, took for drive, she went well, running fine, then came back got enthusiastic, and washed the car, then being a smart arse ..i thought , hey wash the engine bay yeah yahooo.....facepalm, i lightly atomised spray washed, not flloded or doushed the bay!!!!!!!!!......all connectors are rubber fits..sealed, so i thought hey man..what trouble can i get??? i let the engine dry of for half hour, then ran the engine...thinking...mmm the engine heat will dry the bay faster.....so i let her idle for nearly fouty mins....she seemed ok, i took her for a drive.....she was ok.....parked up, left her over n ight This is where the fun began.....start up, ok from cold start.......when she got to normal operateing temp........oppppppssss.....misfire......mmmmm......it will clear i thought to my self....nope.. She getting hot something smells hot..so shut her down....obvious fuel going into the cat............ Well i took all the electrical connectors off to check them, all dry!!! all clean!!..all makeing good contact. I applied Ms4 electrical jelly to all connectors before re connecting for future safe ness from moisture... I checked the distributer/rotor(thease were replaced 2 months ago).....leads, spark plugs(thease were replaced two months ago), all seem fine. I cleaned the throttle bodys and throttle plate, cleaned the stepper motor(it was not gummed up), cleaned the pcv valve and hoses.....i know this fault came after the engine wash.....but i wanted to know that the engine was at a certain point.....all good......so hence why i did this extra work. I find, when i put radio lights interiour fan on, and AC the engine dosnt hold a steady idle...it revs up and down? so this leads me to a assumption..........got be the stepper motor? ??????????????????????????????????/ my interiour warning light Eng diag light dosnt work face palm ...so its not easy to read the flash codes ...or to let the engine talk to me throught this light sigh.............i did a quick check on the stepper motor , and it activates if i put voltage through the middle and earth each outter connector....(can see the stepper rod....move in or out, ) done just a quickly of course.....so this would say to me that the stepper motor is fine? above 1000 the engine seems fine? its below this when shes idling? that the misfire seems to be there? Has anyone a Manuel they can send me via email would be nice......if some one could help please...was hopeing to make the fast and furious meet this weekend!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 I tried wiggling all the electrical egine multi plug connectores....mmmm nothing seems to happen... Quote Link to comment Share on other sites More sharing options...
David P Posted May 23, 2013 Share Posted May 23, 2013 http://www.mkivsupra.net/vbb/content.php?51-Repair-Manuals Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 Oh when i left her to sit over night , when she misfired the next day, i noticed water laying on the engine bottom cover obviously water left over from the wash...so maybe water in the bay over night...got in some where? this is all i can assume ..:/...and maybe the damp enviroment has lead to the misfire...but as i have already said...on inspection.....all connectors were as dry as a desert ???? ok many thanks Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 (edited) Uhm hi mr david p.....uhm many thanks for that link, just tried going there but...... it says i cannot access that site? link? it says i do not have permission to access...im a new member on here...by a half hour? this maybe why...? many thanks for putting that link up...much apprecitated thanks Edited May 23, 2013 by last light bulb (see edit history) Quote Link to comment Share on other sites More sharing options...
Noz Posted May 23, 2013 Share Posted May 23, 2013 you can't access it due to you needing a membership i expect Quote Link to comment Share on other sites More sharing options...
Josh42 Posted May 23, 2013 Share Posted May 23, 2013 Have you tried drying out the spark plug wells mate? I had a similar issue caused by water around the plugs. Take all the leads off and WD40 the connections, then using a rolled up piece of a4 paper, soak up any moisture in the plug wells. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 23, 2013 Share Posted May 23, 2013 then using a rolled up piece of a4 paper, soak up any moisture in the plug wells. Or just blow any water out with a high pressure air line. Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 I see, dang it ..mmm..ok thanks.. Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 Its been 3 days now since i washed the engine?..so i would think she is would dryed out by now? ??? ill take the throttle body off.and take a look at the plug wells, thanks Mr josh.....they have seals around the plug HT tops i notice...anythings possable i suppose...ill try that, uhm Mr Nic...uhm i already tok all engine connector plugs off, and blew through them as well..? they were all dry as a desert honest....ill re do it though....this gunna be a step by step process...i hope ...something hasnt sorted and damaged it self? ... gunna be expensive if it has :/ Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 (edited) ill try and get my eng diag light to work as well sigh .....(more work ha)......i got hold of a manuel now fellas phew ...thanks.........i did hve one before, but my mem stick got pinched .......just vanished from my desk? weird, couple months ago......all strange ..and only time i need it(like now)...its gone......got another manual now though ...... Edited May 24, 2013 by last light bulb (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 gota be something simple..(like me ha ..).......hope it is just water got into the plug wells....... Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 Hey Mr josh!!...did you get weird surge idle as well? with your plug problem? load engine with all electrical , then find the idle fluctuated? Quote Link to comment Share on other sites More sharing options...
Littler Posted May 23, 2013 Share Posted May 23, 2013 Think Josh is right sounds like you have water in the spark plug wells, best bet is to check them before stripping to much off. Especially as you've cleaned the engine. Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 (edited) Well story so far.........number 5 and number 6 (rear spark plug wells fairly full of water-didnt find any mermaids or whales though)....even after 2/3 days since the light atomised spray wash.........dryed out , and dryed the HT ends, re assembled, everything back together...:$ uhm its worse now...arrrrrrrrrrrrrrrrr. alot white smoke out back on the start up......and she has the mis during warm up now too?.......im thinking something worse...sigh.........its 10 pm now nearly 11 im giveing up for the night on it...........mmmmm....this simple clean is turning into a labarinth and head spin...:/ just something to mess up a bank holiday blast it...i tried running her in the dark...so if there was any shorting electic...i would see it in the darkness.....but , i couldnt see any :/ Edited May 23, 2013 by last light bulb (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 (edited) wish i left it dirty now ...becose now the engine is clean, but it is behaving dirty ha Edited May 24, 2013 by last light bulb (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 proceeding to the sparking plugs now fellas , be back in a while ok, many thanks,, any help is really apretiated thanks thumbs up Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted May 23, 2013 Share Posted May 23, 2013 Almost 100% certain it will be water in the plugs. I did the same thing years ago & so have many others. Its a bad design really as there is no way the water can drain out or really escape. Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted May 23, 2013 Share Posted May 23, 2013 Another vote for water around you plugs, usually 5+6, but if you literally sprayed water over the engine then maybe all 6 Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 (edited) im thinking...yes it hurts.... Edited May 24, 2013 by last light bulb (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 (edited) ill whip the plugs out again tomozz... Edited May 24, 2013 by last light bulb (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 im just trying to think , what would be fried....if it did short circuit....why do i feel like a big pit is openng up under me.... thanks for help fellas ..dont feel so alone in this now...thanks Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 (edited) Thanks doctor doom ..mmmm yes does seem a bit of a bad design? why they didnt design a central full cover all the way along is beyond me?..oh well.... Edited May 24, 2013 by last light bulb (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 (edited) ???????????????/. Edited May 24, 2013 by last light bulb (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest last light bulb Posted May 23, 2013 Share Posted May 23, 2013 (edited) ................ Edited May 24, 2013 by last light bulb (see edit history) Quote Link to comment Share on other sites More sharing options...
