brake pipe fittings
girth45
Hi are the brake pipe fitting on the supra metric or imperial, looking to order some brake pipe spanners, im changing the flexis for braided one the weekend. thanks.
Metric, a decent set of metric will get you out of most situations on a car with imperial fittings too. The only one I sometimes struggle with is 14mm - 9/16". It takes a well worn 14mm spanner to fit a 9/16" nut.
All the treads on the supra are metric, excluding the oil filter and tyre valves
He meant the actual fitting, where the spannering is done, not the tread mate.
Edited by pedrosixfour (see edit history)
