Turbo Advice Please....
Andy-No-Knee
I have a single turbo kit at the moment but after buying a new engine (specs below) I'm thinking that a more modern turbo will finish the project off.
The turbo kit I have is a HKS 30/37s turbo. It is good, fast spooling but runs out of puff at the top end. Not sure on what power figure I want but looking at the spec list below I think I am restriced by the 750cc injectors.
Basically I just want to get the turbo without having to get new injectors and other bits, oh and idealy it will fit on the HKS manifold as well saving me even more dosh.
So, the engine is a 1.5JZGTE with the following...
1JZGTE head.
Ported inlet and ported/polished exhaust.
Valve seats reprofiled.
Ferrea 6000 series Valves. Inlet oversized, exhaust standard.
Crower titanium valve springs and retainers
Stem seals replaced
Brian Crower 264/264 cam shafts
HKS head gasket
Greddy Cam Pullies.
Greddy copy larger aftermarket inlet manifold
Seimans 750cc injectors
TTs fuel rail
Aeromotive FPR
2 x Walbro fuel pumps and custom fuel lines.
2JZGTE block.
Block was re-bored for oversized pistons.
Crank shaft lightened and balanced.
JE pistons
Eagle rods
ARP head studs
ARP crank studs
ARP rod bolts
PHR oil pump
Boostlogic Crank pully
Now I really want it to be a fast spooling turbo, and as I say, I'm limited by the injectors which I dont want to change.
Suggestions please..... and thanks!
I keep reading on here about the BW Batmowheels. Are they better than the GTX3882 you have mentioned? Any ideas on the cost front for both?
They are different tech but also about half the price.
The BW EFR series with titanium turbine wheel may have a slight edge but tbh you won't be disappointed with any of the modern double ball bearing turbos of this size.
http://www.enginebasics.com/Advanced%20Engine%20Tuning/Precision%20vs%20Garrett%20vs%20Borg%20Warner.html
Wow!!! Suddenly they are in my price range and not for next year..... Hmmm. Thanks.
So what would be an equivalent BW to the Garrett GTX3582R .82A/R?
I'm doing some reading up on various turbo kits for my new car, just in case I don't get on with the T88-34D :)
Compared with the Garrett GTX3582R .82A/R, I'd probably look at the Borg Warner S360 or a Precision 6266. :)
You can get a BW unit for between £650 to £900 depending on model and supplier, the Garrett units I believe are twice that.
A GTX3576R is around £1000 brand new, although that's without an exhaust housing.
I think I am going to go for a BW S360.
Now the next question is jurnal bearings or double ball bearings? What is the differrnce? I think I know the basic but not the implications.
Are there bearing options for the BW units?
http://www.full-race.com/store/turbos/borgwarner-airwerks/borgwarner-s300sx-83-75-turbo.html
http://www.theboostlab.com/products/borgwarner-turbochargers.html
http://www.theboostlab.com/products/bullseye-power.html
Edited by Wez (see edit history)
  • 3 weeks later...
Does anyone know if the BWS360 comes with an undivided entry?
Or are they only divided entry??
The 60mm units are available with either, I asked the same question in the Whifbitz BoostLab turbo thread yesterday ;)
Where did you get that price from Ian?
I checked ebay.co.uk back then, there were several Canada/USA places that offered them for about £1000 plus pnp. I've just revisited and they've shot up to £1500 delivered :blink: UK prices are a joke, £1600 plus delivery. What a ripoff.
Edited by Ian C (see edit history)
i think this is the cheapest on there at the moment
http://www.ebay.co.uk/itm/Garrett-GTX3576R-Turbine-68mm-84-trim-Compressor-Inducer-Exducer-58-76-6mm-turbo-/250927519653?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a6c7217a5
around £1,250 delivered but more than likely have custom charges
although thats without housing
is that gtx3576r the turbo thats really quick spooling over the others
Edited by ashbuster (see edit history)
