_Shane_ Posted May 20, 2013 Share Posted May 20, 2013 Can someone have a look at the pic please, the banjo bolt connected to the power steering pump has 2 feeds coming off it as you can just about see in the picture. One of those feeds is going to a T-Piece with one side of it blocked off and the other going to the boost gauge This doesnt make any sense to me at all to why its like this. Boost gauge doesn't read anything which is how I noticed this. Quote Link to comment Share on other sites More sharing options...
hodge Posted May 21, 2013 Share Posted May 21, 2013 The 2 vac lines are an idle stabilizer. It's stops your revs dropping when you turn the wheel. 1 pipe goes to a positive vacuum on the intake and the other onto a negitave vacuum on the TB Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted May 21, 2013 Author Share Posted May 21, 2013 I tapped my feed for my defi boost gauge into one of them but it doesnt read anything on the gauge when car is running Could i tap into one of the feeds on top of the intake manifold at the rear (think there is 4 there altogether) Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 21, 2013 Share Posted May 21, 2013 The two hoses go to a mechanical valve that opens as the pump loads up, letting a bit more air past the throttle body. It's an old skool way to compensate for the load on the pump if the steering wheel is turned at idle. Not a great place to T in a boost gauge. You're better off using the feed off the brass barb on the engine side of the intake manifold. Quote Link to comment Share on other sites More sharing options...
