Horn problems before mot!!!
mull1986
Hi everyone thanks for looking at this, my horn has randomly stopped working a week before mot test would you believe and I've checked the 15amp fuse which is fine but can't tell if the larger grey fuse has broken and all wires seem fine and all plugs are ok. Could anyone shed some light on this very annoying and badly timed problem.
Any help would be great cheers :)
I had exactly the same problem, turned out to be the earth wire on the lower horn, i know you said you had checked all the wires, but not sure you are aware that it has two horns, hope this helps.
I didn't know that, that would explain the 2 fuses. Where about's is this as I'm no where near my car atm?
