TT Paul Posted May 20, 2013 Share Posted May 20, 2013 have an issue when starting from hot eng turns over hazards flash ?? a few secs then fires up takes around 8 secs, before DB 13 check codes 12 came up but no eng light at any point, just checked codes . no issues for a few days until i stopped at a set of lights the eng kinda miss fired eng light came on turned off key restarted fine again check codes 13 came up crank sensor again!! but over 750 miles its been fine should i just fit new sensor to rule it out?? Link to comment Share on other sites More sharing options...
TT Paul Posted July 6, 2013 Author Share Posted July 6, 2013 this poped back today any input pls Link to comment Share on other sites More sharing options...
absz Posted July 6, 2013 Share Posted July 6, 2013 (edited) If the hazards are also flashing then i would say its a alarm issues as the crank sensor wiring and hazards are on different circuits.The only thing that can link them is a alarm/immobilizer circuit. Edit Also on supras as long as there is a crank signal going to the ecu then you will see the Rev counter needle bouncing very slightly when cranking. Edited July 6, 2013 by absz (see edit history) Link to comment Share on other sites More sharing options...
TT Paul Posted July 7, 2013 Author Share Posted July 7, 2013 thats handy to know thanks alot:thumbs: Link to comment Share on other sites More sharing options...
