Help with offsets and photoshop
T14PPA
Im looking to buy work meisters but im unsure on colour and offsets so i would appreciate help. Im looking at 10j or 11j rears on stock rolled arches. And 9j fronts. I have uk brakes and im going to buy 18". Can people help me with what offsets ill manage to fit the sizes with?
Also im not sure on what colour to go for. My car is 1a1 and im looking at either gold wid polished lip, black with polished lip, silver with polished lip, or polished completely. If anyone can help me with photoshop i would be thankful. image.jpg
With stock arches
Front: 18x9 +35
Rear: 18x10 +35
Rear: 18x11 +45
If you roll the arches then you could go with a slightly lower offset but the width and type of tyres fitted will also effect the clearance.
Front: 18x9 +30
Rear: 18x10 +30
Rear: 18x11 +40
With stock arches
Front: 18x9 +35
Rear: 18x10 +35
Rear: 18x11 +45
Front: 18x9 +30
Rear: 18x10 +30
Rear: 18x11 +40
Great help mate thank you. Any preference in colour?
- - - Updated - - -
A 255 on a 10" will give you a little space and likewise on an 11" a 275 would have the same effect. Good if you end up with et25 and et35 respectively
Id rather not have a stretch as i want to run the widest tyres possible
  • 2 weeks later...
Hi, dragging up the old offset questions again!
I remember seeing your post when it first went up, and actually took a pic of it ha! Useful info :-)
Ive seen a set of wheels I really like, the offset is et31... But less width than what u have above. Ive used the "willtheyfit.com" to check it. seems ok, but with 12 years on here, do u reckon these would fit with standard arches?
Front : 18x8.5J ET+31
Rear : 18x9.5J ET+31
Would the tyres need a stretch to fit?
Many thanks
Many thanks
They should fit the stock arches okay, with 235/245 front tyres and 265/275 rear tyres you'll probably not need to roll the arches, although it'll be marginal.
