Help identifying sensor and connector blocks please?
Mike_Mac
While dismantling my engine bay the single wire sensor at the top of the first picture sheared when I went to remove it and the connector blocks for both the single and the double wire sensors disintegrated. The pipe's location on the engine is shown in the second picture, with a red diamond around it. In addition one of the Cam Position Sensors connector blocks also fell apart.
image image
Can anyone identify the single wire sensor at the top and/or the part numbers for both the connector blocks on the pipe and the CPS?
Single wire is to the water temperature gauge on the dash. Two pin connector is the water temp signal to the ECU. I have the full Toyota PDF file giving part numbers and illustrations of all the connector shells, and the connector pins with tails for loom repair. Takes hours to go through it, but they'll be in there, send me your e-mail address and I can send it on to you Mike.
You may also find what you need in here, not had time to see how many Andy managed to list in the end!
http://mkivsupra.net/vbb/showthread.php?232824-J-Spec-Engine-Harness-Connector-Details
Edited by Chris Wilson (see edit history)
Chris, that's excellent - thanks very much:salute:
From that post you put up it looks like the details of both of those sensors and the Cam Position Sensor are on there, including the terminals too, which will be handy, as the Temp gauge wire was goosed!
I'll PM you my e-mail address too, as having the definitive list would be really useful, in case I manage to destroy anything else, plus a few of the other engine connector blocks are a bit tired, so I may well go mad while I'm ordering the others!! :D
You won't go TOO mad when you see the prices :) The pdf is not Supra specific, just Toyota specific, it's a nightmare looking at connector shapes, there are hundreds and hundreds of them. Some will look the same, and they are, fit wise, but are different colours. They fail to say what colour though, so it is a bit of a lottery if you worry about trivial things like will it match the socket, or clash with the under bonnet colour scheme :)
Thanks Kris - just managed to get a 2nd hand Cam Position sensor from E-Bay for about 25% of what Toyota wanted for it - looks like that link does the same thing with the water sensor!
Thanks to the file Chris Wilson sent through, combined with other digging, I've managed to get all the part numbers for the connectors, so I'll be ordering them with all the other nuts, bolts, gaskets etc that are needed for the other jobs!
