J Spec O2 Sensor for a 1993 N/A Toyota Supra help!!!!
Guest Jaylovesvegas
Guest Jaylovesvegas
I have been doing some research and I came to the conclusion that the UK spec needs 2 O2 sensors. Is there any difference between my J-Spec Supra to a UK-Supra? And also Where can I find a cheaper alternative then a stock which are very expensive! Thanks in advance. ;)
Graham is indeed correct, surprisingly ;D the N/A has two O2 sensors, one for each section of the manifold, J Spec and UK TT's only have one, when mine needed replacing I ordered them from rockauto, they are made by Denso. Should take around 1 week to get to you, depending on when you order it.
