Gpro Posted May 16, 2013 Share Posted May 16, 2013 I recently converted to single turbo and my downpipe doesn't have a 2 bolt lambda sensor flange only the screw type ones. The car is running on Greddy Emanage Ultimate i have driven it to exhaust shop to adjust the downpipe with no lambda sensor plugged in and the car was fine. Do i really need it? (Also i have a AFR sensor in the downpipe already) Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 16, 2013 Share Posted May 16, 2013 does the untimate have the feature to use the wide band to keep at stoick Quote Link to comment Share on other sites More sharing options...
Gpro Posted May 16, 2013 Author Share Posted May 16, 2013 i believe yes it does. but just found some lamda sensors that are screw on so i will properly just replace it with that (My down pipe has 2 screw type sensor flanges on it) It should be fine shouldn't it? Quote Link to comment Share on other sites More sharing options...
Shane Posted May 16, 2013 Share Posted May 16, 2013 i believe yes it does. but just found some lamda sensors that are screw on so i will properly just replace it with that (My down pipe has 2 screw type sensor flanges on it) It should be fine shouldn't it? You know, I thought all if not most lambda sensors like the bosch one are the screw type. The 2 bolt sensor is normally cat overheat sensor I think. You can sometimes use that location for a EGT sensor, but would need to make a small plate up. Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 16, 2013 Share Posted May 16, 2013 (edited) i believe yes it does. but just found some lamda sensors that are screw on so i will properly just replace it with that (My down pipe has 2 screw type sensor flanges on it) It should be fine shouldn't it? this is exactly what i done http://www.mkiv.co.uk/vbb/showthread.php?262641-n-a-lambda-in-tt Edited May 16, 2013 by mellonman (see edit history) Quote Link to comment Share on other sites More sharing options...
Noz Posted May 16, 2013 Share Posted May 16, 2013 I'm running ultimate on my NA-t. I just removed one sensor and connected both wires to the single sensor in the pipe. Could this not also be done for the TT. Quote Link to comment Share on other sites More sharing options...
Gpro Posted May 16, 2013 Author Share Posted May 16, 2013 so far am leaning towards just getting a screw on one easier the welding a flange. Would it work if i was to tab in to the wiring of the AEM AFR sensor ? Instead of having 2 sensors Quote Link to comment Share on other sites More sharing options...
Noz Posted May 16, 2013 Share Posted May 16, 2013 I'd stay with using a narrow band sensor. The AEM will be a wideband. I'd keep it the same, the stock ECU might throw its toys out if the sensor isn't designed for purpose. Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 16, 2013 Share Posted May 16, 2013 I'd stay with using a narrow band sensor. The AEM will be a wideband. I'd keep it the same, the stock ECU might throw its toys out if the sensor isn't designed for purpose. my wide band wouldnt even work as a narrow simulator as you say and the stock ecu still acted as not connected , hence why i put in another stock sensor just with a thread in the down pipe Quote Link to comment Share on other sites More sharing options...
Gpro Posted May 16, 2013 Author Share Posted May 16, 2013 Already thank you for your help i will get a screw type lambda sensor Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 17, 2013 Share Posted May 17, 2013 Don't forget that with the EMU you are using the std ECU for most of the closed loop areas IE lambda feedback, although you can feed a synthesized narrow-band signal to the ECU i have found the std ECU prefers a strait feed from the std sensor, and in any case its pretty much a waste of time trying to fight the std ECU with settings changed within the closed loop areas using the EMU without some form of lambda tweaking. Quote Link to comment Share on other sites More sharing options...
