TubbyTwo Posted May 15, 2013 Share Posted May 15, 2013 Hi folks, Going to be testing the supra this weekend, have an on going tps problem which I think we have narrowed down the VTA wire. To test going to de-pin the TPS plug and ecu connector and run a separate wire between the two. Have just found a new role of speaker wire, would this be OK for test/temporary purposes? or can anyone recommend an alternative. Thanks Si Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 15, 2013 Share Posted May 15, 2013 depends on quality of speaker wire really some are good some are rubish but you could twist both parts together to make a better single wire , not the best but would work as a test imho Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 15, 2013 Share Posted May 15, 2013 It'll be perfectly fine, it's just a 5v signal line Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 15, 2013 Author Share Posted May 15, 2013 Thanks Ian Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 15, 2013 Share Posted May 15, 2013 I use gardening wire to bridge the diagnostics port Quote Link to comment Share on other sites More sharing options...
