Frontal area
Digsy
Interesting. I assume that the figures that it is pre-populated with are just an example?
yeah, you need to enter your own 60-55mph and 15-10mph figures, as well as true total weight.
You can measure the decel figures using the accelerometer, making them much more accurate than looking at the speedo and your watch :read:
Doesn't that calc imply that the coefficient of rolling resistance is a constant, though?
I'm not sure, I remember that both calcs use both time measurements. I've got them somewhere, they were in the manual.
So it gets an idea of the 'tailing off' that happens as speed increases
It should be easy to verify.
I think the website calc uses small decels so that it can be pretty sure that the deceleration will be almost constant over the time. If you know the decel and the vehicle mass, you can work out the retarding force.
The retarding force will be a sum of the rolling resistance force and the aero drag force.
If you assume rolling resistance force is constant, and aero drag force is directly proportional to speed, then if you plot retarding force versus the square of the average speed during the decel, you will get a straight line.
The slope of the straight line will be Cd x frontal area x air density / 2
The line intercept on the Y-axis will be Crr x vehicle mass x 9.81
I think. :)
So if you take three decels instead of two and plot retarding force against average speed^2 and they do not fall on a straight line, then the Crr must also vary with speed.
At this point I'd like to make it clear that I do have a healthy sex life.
I've extracted a frontal area (appoximation) of 3.37, but I've yet to find what it's measured in, heh...
My initial measurements were not very accurate, I have doubts as to how 'level' my road is (VERY important for these tests) and it is hard to measure these things even with light traffic around (the 20->10mph measurement was the hardest one, there is always some dumbass appearing from nowhere and trying to 'play')
I tried 3 measurements for each, so I could use the average, but the variance was too high. Anyway...
I also said 'square' when I should have said 'cube'
I just did a rough-as-a-bear's measurement of the frontal area and it came out at 2.1m^2
Sounds a bit on the low side to me. I'll have to do it again but on paper using a proper front view and some basic measurements for scale.
OK. I just worked this out using a scaled picture overlayed with a 10x10cm grid and I reckon the frontal area of a bog-stock Supe is:
2.07m^2
Which means that if the book figure of 0.33 for the Cd is 0.33, then Cd.A should be no more than 0.69.
So summat is up somewhere. :(
  • 5 months later...
i've got something that draws power graphs from ecu log files. it seems really good. i just need an accurate frontal area and weight.
how will a coastdown give an accurate CdA figure? isn't there too many other variables to make it accurate?
