hodge Posted May 14, 2013 Share Posted May 14, 2013 Hi guys Can anyone confirm the thread side on a stock fuel filter. Now I know the front is m12x1.25mm but I need to know the size of the rear thread that the hard line screws into. I'm sure it's a tapered thread possibly 3/8 NPT but I need someone to confirm. Cheers John Quote Link to comment Share on other sites More sharing options...
JasonR24 Posted May 15, 2013 Share Posted May 15, 2013 Does anybody know this? Cheers Quote Link to comment Share on other sites More sharing options...
antno Posted May 15, 2013 Share Posted May 15, 2013 Sorry to hijack your thread but is the back of the std fuel rail m12x1.25 as well? Cheers Anthony Quote Link to comment Share on other sites More sharing options...
hodge Posted May 15, 2013 Author Share Posted May 15, 2013 Sorry to hijack your thread but is the back of the std fuel rail m12x1.25 as well? Cheers Anthony Yes Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 15, 2013 Share Posted May 15, 2013 M14 x 1.5mm No taper, the formed pipe end seals against the dome in the filter inlet. Just checked the old, original, filter I changed a couple of years ago. Quote Link to comment Share on other sites More sharing options...
Mugello Posted May 15, 2013 Share Posted May 15, 2013 Hodge dont you run an aftermarket fuel filter ? Quote Link to comment Share on other sites More sharing options...
JasonR24 Posted May 15, 2013 Share Posted May 15, 2013 Hodge dont you run an aftermarket fuel filter ? It's for mine I need braided lines and all connectors as I can't fit stock lines l back to my shell Quote Link to comment Share on other sites More sharing options...
hodge Posted May 15, 2013 Author Share Posted May 15, 2013 M14 x 1.5mm No taper, the formed pipe end seals against the dome in the filter inlet. Just checked the old, original, filter I changed a couple of years ago. That's perfect, cheers bud. Quote Link to comment Share on other sites More sharing options...
JasonR24 Posted May 20, 2013 Share Posted May 20, 2013 Was wondering if anyone knows the hose size required for the return pipe? Is it 6 or 8mm? Cheers Quote Link to comment Share on other sites More sharing options...
