shaz2010 Posted May 13, 2013 Share Posted May 13, 2013 I've used the search button but can't find and clear answers. On removing the first and second cat to fit a decat do I just tie the exhaust temp sensor (that's located in the second cat) up with a cable tie? Or is it needed ? Cheers shaz Quote Link to comment Share on other sites More sharing options...
Benjy Posted May 14, 2013 Share Posted May 14, 2013 Just tie it up out of the way Quote Link to comment Share on other sites More sharing options...
hodge Posted May 14, 2013 Share Posted May 14, 2013 You can either do this or lift the drivers carpet, unplug the sensor from the loom and just stick a bung in the hole. I'm not a fan of cable tieing sensors up, personally I'd remove it and bung the hole correctly. Quote Link to comment Share on other sites More sharing options...
